Old 05-08-2005, 03:22 AM   #1
Central heating 3 way valve
My Ravenheat combi boiler RSF820/20T 3 way diverter valve failed and I have just replaced it. While the domestic hot water flows freely through it the central heating portion refuses to fill. What is odd is that there is an arrow on one port of the valve which one would assume indicates direction of flow but the only way the valve fits has domestic hot water flowing out through that port when the arrow indicates in the other direction. I am absolutely positive the old valve was fitted in the same way. Any suggestions would be appriciated, it may be spring time but it's still wooly hat weather in Aberdeen.
KevinO is offline   Reply With Quote
Old 05-11-2005, 12:09 AM   #2
Inspect your central heating system for a bleed valve, hook a hose to it (if found), open the valve, and turn the system on to heat. If it is an air lock in the system this should bleed it out. You may also have to remove a cap on the pump for the heat system, and force the pump to start up (usually done with a screw driver), then bleed the system out.
Tomm is offline   Reply With Quote
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
