Old 07-02-2005, 12:42 PM   #1
Exclamation
central ac, shooting water
hello,
i recently moved into a house with central ac. i never had central ac before. my question is: there is a copper tube which i beleive is comming from the the compressor, which is in the house, in a closet, its about 3/8" od, and stands upright next to the condensor (i think that is it the condensor?) outside the house. the end of the tube is blocked off with what looks to be wood puddy, why i dont know. the tube has a split in it, near the bottom, that looks like it burst from being frozen. the tube will release a spray of water about every 20 minutes of operation. is this normal, and why is the the tube sealed off? the ac seems to work very well!
thank you,
bob
bobo is offline   Reply With Quote
Old 07-15-2005, 03:31 AM   #2
Originally Posted by bobo
hello,
thank you,
bob
AC needs to pump the water it creates out. The copper pipe is supposed to be empty, it must have gotten clogged somehow, filled with water, frozen, burst, and now its just doing its job again pumping water out. Unclog it, or cut it short at the break point, redirect it where you want it and voila.
Its all normal.
Knyte260 is offline   Reply With Quote
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
