Cement Utility Sink - Cracks And Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2007, 07:08 PM   #1
Cement Utility Sink - Cracks and Leaks
Does anyone know if there is a product to seal up either the inside or the outside of an old cement utiliy sink. Mine has several hairline cracks in it and they leak just a few drop everytime my washing machine drains into the sink. I'v heard there is a rubber like product for these old sinks that can be painted on to completely seal them up, sort of like truckbed liner. Has anyone heard of this or know of any other product that might work?
amazinlittledevil is offline   Reply With Quote
Old 01-23-2007, 06:42 AM   #2
Check on swimming pool paint. Whatever you use, it will probably be Latex. Good luck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-23-2007, 06:49 AM   #3
epoxy of some sort
gitnerdun is offline   Reply With Quote
Old 01-25-2007, 02:59 PM   #4
I ended up using Drylock for basement and foundation walls. It worked out great. It even says on the can that it can be used for sealing bird baths with standing water.
Cracks in foundation....leaks....need some info. wackerjr Building & Construction 5 06-12-2006 01:15 PM
