Old 03-24-2009, 01:17 PM   #16
SAS
cement truck over sewer line
Originally Posted by 4just1don View Post
If its A LOT of cement get a pumper ,,,but costs are going up quick!!!
I could get a pumper... but I also need to get a lot of gravel in a dump truck. I bet it'll be about as heavy as the cement, but maybe not. I'd hate to have to wheel all that down the driveway, but it might be the only option...
SAS is offline   Reply With Quote
Old 03-24-2009, 01:35 PM   #17
Remodeling Contractor
Again, check the cost of powered wheelbarrows.. that is what I use. Most all the time additions are in the rear with no access via truck. and if the truck gets stuck you have to pay for the tow and the extra time to get him out.
Old 03-24-2009, 02:08 PM   #18
SAS
Originally Posted by Bob Mariani View Post
I've tried to use 2X materials and several sheets of plywood moving cement with my skid steer bucket and it still will snap these materials. Like you said it is your opinion that counts and it is you that has to hear about the yard smell to your neighbors after you break the sewer line.
What do you think about using old railroad ties? I could lay a bunch of them side by side perpendicular to the ditch and then attach them together so that the truck wouldn't move them...
Old 03-24-2009, 02:40 PM   #19
If you have them these will work over 3/4" plywood to spread the weight.
Old 03-24-2009, 09:14 PM   #20
Did you look into renting a power buggy for a couple of days? Less work than building a bridge out of railroad ties. You can use it for the gravel and also for the concrete. That would be my choice.
ponch37300 is offline   Reply With Quote
Old 03-24-2009, 10:07 PM   #21
SAS
I'm going to look at prices.
Tags
cement, concrete, sewer, truck, underground
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
sewer line back fall oakie14 Plumbing 2 09-04-2008 06:36 PM
Leaky sewer line rockabelly Plumbing 10 09-12-2007 10:39 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
