Cement Truck Over Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2009, 11:42 AM   #1
SAS
cement truck over sewer line
I'm looking at pouring a slab in my backyard. I recently dug in a 4" schedule 40 sewer line that connects to the cast iron main - also in the backyard. It connects at about 4 feet underground and the run of the sewer line gradually rises from that 4 feet to about 18".
My question is whether it is safe to drive a cement truck over this connection and new sewer run. The cement truck would drive over the Ell connection to the cast iron main. It's 4 feet underground and we backfilled and tamped as best we could, but there is still inevitable settling that will take place. The truck would also drive over some of the 4" pipe at a place where it is about 24"-30" deep.
Do you think this is OK? The concrete guys do, but they're also looking for the easiest way to get the job done.
Thanks for the advice.
SAS is offline   Reply With Quote
Old 03-23-2009, 01:10 PM   #2
If your pipe was properly bedded, backfilled, and compacted you should be OK.
porchmonkey is offline   Reply With Quote
Old 03-23-2009, 01:15 PM   #3
47_47's Avatar
Rewards Points: 76
You could put down planks over the pipe to distribute the trucks weight.
47_47 is online now   Reply With Quote
Old 03-23-2009, 03:00 PM   #4
HVAC / Plumbing
IMO I wouldn't risk it.. It may take a little longer but, There are other means ( machinery) to get the concrete to the area
kenmac is offline   Reply With Quote
Old 03-23-2009, 04:15 PM   #5
Remodeling Contractor
They do not look for the easiest way, he is just giving his opinion as we do here. 2-3' is not very deep. You do not know the soil conditions or compaction. I would not chance it. Power wheel barrows are great for this work
Old 03-23-2009, 04:24 PM   #6
How wide was the trench?
Old 03-23-2009, 05:47 PM   #7
Compaction and soil conditions are everything. I crushed a 10 foot section of Schd 40 at a 4 ft depth where the ground was a little soft. I go with the person reccomending the planks for weight distribution.
AJ&J is offline   Reply With Quote
Old 03-23-2009, 06:17 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,... A few sheets of 3/4" plywood would go along ways,... Cheap Insurance....
Bondo is online now   Reply With Quote
Old 03-24-2009, 07:50 AM   #9
SAS
width
About 12", but at the point where the connection was made it was a 3' x 4' foot hole about 5 feet deep.
Old 03-24-2009, 07:52 AM   #10
SAS
wood
Do you think that that would hold a fully loaded cement truck? I was thinking 2x10s...
Old 03-24-2009, 08:27 AM   #11
47_47's Avatar
Rewards Points: 76
I too was thinking 2x material. I would NOT let the truck drive over the connection hole, just lay the planks perpendicular to the trench.
This is my opinion only, ultimately it is your decision.
Old 03-24-2009, 09:00 AM   #12
Rewards Points: 562
2x planks will snap like a toothpick to even a half full cement truck. Better find some bridge plank material. 'Here' that would entail finding where the county crew took out an old bridge lately and reclaiming a bunch of old used stuff. A double layer would not be too much,,and it better be on hard level surface,no holes or voids under neath. recently dug up soft dirt WILL collapse under truck weight if its damp. has it rained in the last two weeks?? Your 2X material MAY work to run a manuel wheel barrow on. If its A LOT of cement get a pumper ,,,but costs are going up quick!!!
4just1don is offline   Reply With Quote
Old 03-24-2009, 10:14 AM   #13
I've tried to use 2X materials and several sheets of plywood moving cement with my skid steer bucket and it still will snap these materials. Like you said it is your opinion that counts and it is you that has to hear about the yard smell to your neighbors after you break the sewer line.
Old 03-24-2009, 10:57 AM   #14
47_47's Avatar
Rewards Points: 76
SAS,
I just re-read the entire thread and I missed Bob's first post about not knowing the soil conditions and compaction. Sorry for my misinformation.
Old 03-24-2009, 12:15 PM   #15
SAS
That's a good idea,
That's a good idea, but then I also have to have a fairly heavy truck to haul that material in...
It rained a week ago. The deepest section is fairly shaded as well. It's probably still damp down there.
Tags
cement , concrete , sewer , truck , underground
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
sewer line back fall oakie14 Plumbing 2 09-04-2008 05:36 PM
Leaky sewer line rockabelly Plumbing 10 09-12-2007 09:39 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
