Old 10-29-2009, 11:31 PM   #1
Default Cement hole in back yard is it a old septic???
I just bought a 80 year old house and i was moving a flower pot in my back yard that was right next to cement patio. I uncovered a cement hole that was half full of junk and debris. The hole had cement walls. I dont know what to do does anyone know anything about this or have they heard of anything like this.
cadet4206 is offline   Reply With Quote
Old 10-29-2009, 11:49 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
How big is it?
Also used to be garbage pits at houses
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 10-29-2009, 11:53 PM   #3
the opening it self is about 3-4 ft wide if i were to go on the hole is probably 6-8 ft wide may be 6- 10 ft tall looks like a cement cube or tank of some sort..... What should i do????
Old 10-29-2009, 11:59 PM   #4
Scuba_Dave's Avatar
Do you have a septic system ? Town sewer ?
Its not being used for drainage or dry well?
You'd need to fill it, does it smell ? Wet....dry ?
Old 10-29-2009, 11:59 PM   #5
Custom Cabinet Maker
If the "tank" appears to be made from blocks with some space between them it could very well be an old septic tank. B4 they used separate leeching fields this is how they let the liquids drain off and the solids settle to the bottom.
Best thing to do is pull the top off,clean the garbage out of the pit and fill it in
skymaster is offline   Reply With Quote
Old 10-30-2009, 09:04 AM   #6
See if there is an inlet pipe opening and/or outlet pipe opening on the other side. These will usually be not far from the top.
A decommissioned septic tank (or dry well / cesspool) is filled in in order that what you put on top does not cave in.
A septic tank or cistern has solid sides and bottom. A cesspool / dry well has porous for example unmortared brick walls.
Garbage pits are typically less than 2x2 feet across.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
Old 11-02-2009, 11:38 PM   #7
I found out what it was........ Water cistern
More On This Topic
Many people have decided to abandon their old septic systems and tanks and get tied into the public sewer system in their area. This decision leaves homeowners with unused septic tanks on their property. Although septic tanks are buried underground, the... Read More »
Knowing what type of septic field tubing you need for your leach field is important. Selecting the size, type and configuration of pipe can mean the difference between your leach field working and having it fail. To be sure you have the right pipe for... Read More »
Cleaning a bathroom that empties into a septic system requires more thought than one that feeds into a city water supply. One does not want to mess up the required bacterium and percentages needed in the septic tank to keep it properly balanced. You do... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
How to Wash Windows: Soap
How to Wash Windows: Soap by Expert Village
This is Christopher Lyman with expertvillage.com and the next thing we are going to talk about is soap. What I like to use and what most professional window washers use is some form of dish soap. I like Lemon Joy. This is in the highly concentrated form... Read More »
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 04:25 PM
interlocking at the back yard KUIPORNG Landscaping & Lawn Care 10 09-14-2007 10:24 AM
Back yard now leaking "black water" tripower Plumbing 5 08-06-2007 06:56 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-10-2007 12:03 AM
Back Yard Surfaces EAMVT94 Landscaping & Lawn Care 7 03-29-2005 12:52 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
