Cement Board At Tub Lip - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2013, 03:02 PM   #16
Could you fill the space between the tile and tub with chalk only? Best way to cut half inch cement board? Can cement board be put up over existing drywall /plaster? I also have to ask this one, I was watching a home depot video where the guy started tiling at the top and went down, he taped each piece together as he went. Is that how a pro would do it?
paintdrying is offline   Reply With Quote
Old 02-22-2013, 03:08 PM   #17
Originally Posted by jagans View Post
1. Always give the water a way to exit the system. If you do not, it will find its own way.
2. Always shingle materials to drain, even if they are considered water proof.
I think that is what we are all desperate to do - find the best way to build and let the water drain....
That gap above the tub is so worriesome...hence the questions
mplut is offline   Reply With Quote
Old 02-22-2013, 05:30 PM   #18
DIY staff
Rewards Points: 7,174
I'm not sure if the thinset will bond to caulk----
Tilers mesh looks like drywall mesh tape---except it is alkali resistant--so it won't dissolve when embedded in thinset---
1/2 inch cement board ,like Durrock, can be scored and snapped like drywall--curved cuts can be made with a jig saw and a carbide blade--
A diamond blade in an angle grinder will work well for the zig zag cuts--
Or a hand held diamond circular saw--with a wet sponge against the blade---
Only on You Tube will any one start tiling at the top of a wall----
Frequently a wood ledger board is screwed to the three walls--leaving out the first row of tiles----then tile upwards ,using the ledger to keep the tiles from slipping---
After the tiles are set---the ledger is removed--screw holes waterproofed---then the bottom row is set----
Old 02-22-2013, 09:13 PM   #19
Yes good to go with what you want to do good luck
joes plumbing is offline   Reply With Quote
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
cement board flex (a bit) rtoni Building & Construction 2 12-16-2010 02:01 PM
Cement Board cougar01 Flooring 2 10-29-2010 03:35 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Cement hardy board tmiles2246 Flooring 9 05-11-2009 04:10 PM
