Ceiling Mount Rain Showerhead - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2012, 06:03 PM   #1
Liv
Ceiling mount rain showerhead
Anyone know of some good online resources for purchasing a ceiling mount rain shower head and handle? Most of the ones I can find only come with the rain shower head and arm (to attach to the ceiling), and I guess I'll have to buy the handle separately? Looking for something like this:
http://www.signaturehardware.com/product18555
Liv is offline   Reply With Quote
Old 03-28-2012, 06:27 PM   #2
DIY staff
Rewards Points: 7,174
What handle are you speaking of?
Old 03-28-2012, 06:55 PM   #3
Rewards Points: 252
I've always been happy with the quality of stuff I've gotten from Signature Hardware
shazapple is offline   Reply With Quote
Old 03-28-2012, 10:16 PM   #4
Rewards Points: 616
look at kohler they have some awsome ones just type in model # on google ang that will give you some
http://www.us.kohler.com/onlinecatal...l&sort=Default
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-28-2012, 10:59 PM   #5
Liv the handle you're talking about is the shower diverter, correct? If so then that is located just below the product picture in the additional related items category.
VIPlumber is offline   Reply With Quote
Old 03-29-2012, 09:47 AM   #6
Liv
Thanks guys- I ended up just purchasing the 16" rain shower head that I linked to, with the 3-way diverter and 12" arm. I have a question about the diverter, though. Does that turn the water on as well? We want the shower head to run separately/independantly from the regular shower head. I'm hoping I can plug 2 of the 3 outlets and have this work just like a normal shower lever handle....if that makes sense.
Old 03-29-2012, 10:28 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
A diverter valve only directs the output of the water. You need a thermostatic valve to control the temperature of the water as well.
It will not work as you describe.
Furthermore : If you are buying a 3 function valve, and you only need to divert between 2 functions, make sure that the valve you have will still work if you plug one of the ports.
Journeyman Plumber
Old 03-29-2012, 12:03 PM   #8
Liv
Yeah- I figured that out right after my post and cancelled the diverter valve portion of the order.
That was my bad.
Anyway- I'm thinking I may be able to get by with just a regular single handle shower valve that controls both the water temp and pressure at the same time (controlling the rain shower only). Do you think that will be okay? That is what our plumber suggested, he says it will work just fine. I've seen some rain shower heads with separate controls for both the water temp and water pressure, is that always necessary?
Old 03-29-2012, 10:10 PM   #9
Doing it myself
Alan's Avatar
That was my bad.
They make valves that control both functions on one handle. The action of the handles is different depending on which brand you decide on.
So you're wanting to put a new shower valve in, and it will control only a rain head?
Journeyman Plumber
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
NEC for ceiling mount light bathroom npbsurfr Electrical 2 11-12-2010 09:32 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Flush Mount Ceiling Fans argana Electrical 6 01-05-2008 06:43 AM
How to mount a ceiling fan to an overhead beam rtyui2 General DIY Discussions 3 12-17-2007 04:29 PM
