Caulking Stainless Steel Kitchen Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2014, 11:33 PM   #1
Rewards Points: 27
caulking Stainless steel kitchen sink?
I am going to replace my kitchen sink with a Delta SS sink and faucet set.
The sink has a rim seal about an inch from the edge, and the instructions don't say to use any caulk. It has 8 clamps to secure it. The section describing the tools you will need, lists "clear silicone putty, if this is a remodelling job"?, which it is.
So, should I use any caulk or no? this is just going on a cheap laminate type counter top.
Another question I have but isn't as important is the strainer assembly has a gasket, so I'd assume no putty is needed for it. I could always put some in later if it ever leaks.
thanks
blott0 is offline   Reply With Quote
Old 03-25-2014, 11:43 PM   #2
Rewards Points: 14,010
I use silicone caulking under the rim of the sink.
No caulking and the countertop would be destroyed as soon as the water hits the particle board.
Use plumbers putty under the rim of the strainer, the rubber and paper gasket goes under the sink, paper toward the nut.
Old 03-25-2014, 11:47 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 814
I run a bead of Dap kwick Seal latex silicone caulk around the perimeter of the sink hole before setting sink in. some folks also apply a layer of silicone to particle board edge of the cut out. These are precautionary steps in case water seeps under the rim.
After mounting the sink and faucet, I also run a tiny bead where the sink meets the counter top. for this step I use clear caulk on SS sinks. I wipe away the excess with a damp sponge or wet finger- be to use latex though as it cleans up with water.
For the strainer- I set them in plumbers putty every time. On the bottom side, the rubber gasket goes against the sink, then the paper friction ring, and last, the nut.
Hope that helps
Old 03-26-2014, 09:42 AM   #4
Rewards Points: 27
Thanks for the info, I will use some caulk. Wonder why they only mention it in the reference to remodel?
Just looking at the instructions again re, strainer, and it definitely shows strainer, gasket, sink, rubber gasket, plastic drain. The gasket that I think goes on top side is a thin foam, not sure if when you say paper gasket, if that is literal or just what it's called.
Old 03-26-2014, 09:32 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
Toss the foam use the putty or leave the gun bring the cannoli
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 09:32 AM
Stainless Steel Sink Question jamiedolan Remodeling 3 05-01-2011 07:35 AM
Stainless Kitchen sink.. What to get? AdRock Kitchen & Bath Remodeling 3 03-03-2010 08:27 AM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 09:16 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
