Caulking Around The Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2013, 09:05 PM   #1
Rewards Points: 31
Caulking around the tub
Recently replaced the caulk around the the bath tub and a small area under the where the shower head is keeps coming off. I give it 36 hours to dry before anyone uses the shower, and it dries hard. However, after a few showers, it's soft and mushy and starts coming off. The rest of the tub is fine. I have a filter on the shower head that drips while the shower is running (replacing it ASAP), right onto that spot so that's a big part of the problem, but also wondering if the caulk itself is no good. I use DAP, no voc, made for bathrooms. Is that just bad stuff? Or would any caulk no be able to withstand the drip? It only drips a small amount, only when the shower is running. I would think that it would be able to hold up under that.
jmorc2003 is offline   Reply With Quote
Old 02-26-2013, 10:53 PM   #2
Rewards Points: 156
Not sure but if you've done this a few times and it keeps happening may e you should try one of these adhesive caulking products that you peel and stick.
strategery is offline   Reply With Quote
Old 02-27-2013, 06:25 AM   #3
Rewards Points: 13,712
Are you trying to use caulking to seal a pipe fitting?
You need teflon pipe tape or dope for that not caulking.
That filter is causing a back pressure and reducing the flow. Get rid of it and the leak may stop.
Anyplace around the tub to wall joint needs silicone caulking not latex.
All the old caulking needs to go and area cleaned before new goes on. New will not stick to old.
Got any pictures?
Old 02-27-2013, 10:10 AM   #4
Roofmaster
Rewards Points: 2,210
OK, why the heck is there a filter on the shower head?????
Old 02-27-2013, 02:33 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 394
Believe it or not they make shower heads with a built in filter.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-27-2013, 04:13 PM   #6
Household Handyman
Rewards Points: 1,408
Someone posted a very good, although lengthy, article on this site some time back on why certain caulks would not adhere to certain surfaces of bath/shower units. He gave good detailed information as to how to properly clean the surfaces for different caulks. Try a search on this and see if you can find it. Hopefully the article will help.
Exterior Window Caulking Amitabh Windows and Doors 7 11-13-2012 10:37 AM
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 10:49 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 05:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
