Caulking around bathroom sink
If it is silicone caulk you can't paint it. If it is non silicone you can. Ask them what they used. They should have removed the old caulk before applying new. Poor workmanship. You can also remove it yourself and re caulk it. If it is silicone be ready for some elbow grease but this is what should be done. What color caulk did they use? Clear? White? If you can see the old through it it might be clear. Remove it if you want a nice finished look.
Minichillo's Construction
I will never leave you hanging!
