Old 09-08-2008, 05:10 PM   #1
cast toilet flange
I have a toilet to replace, the problem is its a slab,and the plumber doing the rough in did a half@ss job.The flange is cast,and the foam they use to protect the pipe when they pour the slab was never cut back and flange not secured to drain pipe which is also cast,so there is no way to tighten bolts without slipping flange out of line ,is there some type of epoxy or a way to secure it si I can tighten toilrt down?
Thanks in advance
Z
zombie911 is offline   Reply With Quote
Old 09-08-2008, 07:53 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
cast toilet flange
Hey Z,
The flange is supposed to be set above the finished floor level (bolted to it) with only the thickness of the flange (1/4" +/-) above the finished floor level.
You just need to get Tapcon screws (made to be screwed into concrete) and the proper size masonry drill bit for them, to install the flange.
Good Luck.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-09-2008, 12:00 PM   #3
cast toilet flange
Thanks for the response Mike, there was nothing to screw to. A plastic tub was used around the flange when they pour,so the flange does not really sit on anything...I did find a flange with a tapered and threaded tail piece,where the rubber ring sits inside the the 90 and you screw the flange in,being tapered it tightens up.
Thanks again
Old 09-11-2008, 03:47 AM   #4
cast toilet flange
WTF
Old 09-11-2008, 09:06 AM   #5
Moderator
Termite's Avatar
cast toilet flange
Originally Posted by zombie911 View Post
WTF
For clarity, this post was in reference to a POINTLESS SPAM post that I've removed from this thread. ***thekctermite***
cast iron flange Jrebhun Plumbing 2 09-06-2008 01:45 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 08:40 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 10:41 AM
