Cast Iron Vs Galvanized Steel. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2007, 02:19 PM   #1
Cast iron vs galvanized steel.
My inspector told me that i have both Cast iron and galvanized steel waste pipes. How can i tell the difference between them? I know from a practicality standpoint cast iron is good and galvanized steel is bad. So i want to try and find out what pipes i need to remove.
What is the best way to describe /tell if it is galvanized stel pipes? They are probably 40 yrs old.
Thanks,
Avi
duffers is offline   Reply With Quote
Old 11-08-2007, 02:48 PM   #2
Rewards Points: 150
difference
Cast iron pipes usually come in 3-4-5' sections with a big bell end on one end and are leaded together where they join. Galvanized pipes are brighter grey (more) shiny looking smooth pipe with 'threaded' ends into a cast or iron elbow or tee, BUT generally threads still show a little. Cast iron is very thick and heavy. Galvanized not nearly as heavy. Galvanized is 'usually' used for sink drain,,,like 2" or 1 1/2",,,cast is 2-4 " diameter and usually used in that era of homes for the stack all the way to the roof. BOTH can be troublesome and rust thru. IF cast stack is bad you have to replace anything on top of problem area,,,best with newer PVC plastic. easier and better to work with!! Like a chimney IF you start from the bottom you may end up with whole thing on your head!! MAY require walls to be opened up for access. Whenever I would reroof with a cast stack I at LEAST replace the top thru the roof portion!!(flashing and sealing reasons.) It is all GOOD as long as it works, drains, and doesnt leak!!! Find another place to spend your money instead,,,until the time comes OR you have walls and access open anyway!!! Cast to plactic hubs are available,,,as it no hubs and rubber hose clamp connetions to connect galvanized to Plastic. Galvanized water supply pipes are also common to this era of houses!!! IF it is soft lead(either inside or supply line into house!!!),needs to be replaced for health reasons!!
justdon is offline   Reply With Quote
Old 11-08-2007, 03:36 PM   #3
Thanks.. My supply pipes are copper so that's good.. I was trying to figure out which pipes were galvanized so i'd know which to replace. Trying to replace it before it starts leaking. However, according to what you wrote it probably makes sense to replace them both?
Old 11-08-2007, 04:49 PM   #4
Send a message via AIM to Marlin
Why are you changing them?
If you're doing a re-model and are going to have all the walls out I would defiantly re-pipe everything. If you're just changing pipes to change pipes I wouldn't even bother. When something starts leaking fix it then. I wouldn't bother changing the cast either, especially on the stack.
Marlin is offline   Reply With Quote
Old 11-09-2007, 11:22 AM   #5
I was thinking of changing them to avoid having a leak and then having to repair that damage.. They are 48 years old.
Old 11-09-2007, 11:50 AM   #6
47_47's Avatar
Rewards Points: 44
When you change them, I would wrap them with insulation. PVC is noisier than cast or galvanized.
47_47 is offline   Reply With Quote
Old 11-09-2007, 12:09 PM   #7
You can tap on the pipes with a metal screwdriver. Cast iron will give a "thud" sound as it is thick material. Galvaized is more of a "pinging" sound. If you get into replacing the piping, you will find cast iron for the mains and threaded galanized piping connecting to it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-09-2007, 03:28 PM   #8
Rewards Points: 150
My house is about 65 years old. I got about the full spectrum of waste pipes: PVC, copper, lead, etc etc. But main stacks (two of them) are cast iron, and show no sign of problems.
My neighbor's house is 85 years old, and his cast iron stacks are among the few things that survive from original construction. So, your cast iron still got quite a bit of time to go. But galvanized.... I'd worry. I hear its lifespan is around 40 years. MY house does not have a bit of galvanized (as far as I could determine).
scorrpio is offline   Reply With Quote
Old 11-11-2007, 03:25 PM   #9
Rewards Points: 150
I have seen cast leak
I have seen cast iron stacks leak,,,but I have seen 100-year old stacks NOT leak either. Problem with cast IS as a horizontal drain pipe it settles shut with crap like they all do. Cast is 'rough' on the inside so it tends to clog faster.
Now dont get me wrong,,,I dont say replace JUST to have something to do,,,,BUT ,,,,I have seen where they charged MORE to clean a drain than somebody could have cut it ALL off and replaced THAT part ... Most anybody can cut and glue!!! Like a laundry sink horizontal drain,,,soap scums it up terrible. Snake it out till it drains too hard and whack her off and switch to plastic with a good slope,works MUCH better!!
Old 11-11-2007, 07:16 PM   #10
joed's Avatar
Rewards Points: 11,616
I believe there are some regions that still require the use of cast. Check you local codes before you replace it with PVC or ABS.
Old 08-04-2009, 11:35 PM   #11
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
piping
If it is not broke dont fix it .
lonsplumbing is offline   Reply With Quote
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 11:58 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 08:09 PM
How to? Cast Iron Stacks. mjnovak77 Plumbing 9 09-14-2006 09:46 PM
