Cast Iron Toilet Flange (pics) - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2011, 10:55 AM   #1
jelly's Avatar
Rewards Points: 330
Cast Iron Toilet flange (pics)
I am in the process of gutting my bathroom in which I will be installing a new subfloor, Ditra and 12" floor tiles. When I pulled the toilet up I noticed the flange was rusted out. Upon further inspection it looks like the flange is welded to the sewer line.
1) Should I remove the old flange? What is the easiest way to remove it?
2) Or do I keep the flange in place and install one of those PVC Twist-N-Set Closet Flanges?
If you suggest option 1, what would I use to connect the new pvc flange to the old cast iron sewer line?
If you suggest option 2, how would I cut the old flange down so the new Twist and set isn't too high.
Thanks for your time.
Cast Iron Toilet flange (pics)-photo-411.jpg   Cast Iron Toilet flange (pics)-photo-38.jpg
jelly is offline   Reply With Quote
Old 07-02-2011, 11:10 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Looks like cast iron to me, but i could be wrong. It should be leaded, not welded.
If it's cast iron you can drill around the lead joint to help get the lead out. Once the lead comes all the way out, there's a fiber material stuffed in there called oakum. After pulling out the oakum, the flange should be free, and you'll just be left with a 4" 1/4 bend sticking up.
Journeyman Plumber
Old 07-02-2011, 11:18 AM   #3
jelly's Avatar
Rewards Points: 330
Hi Alan, you are correct. it is leaded cast iron. When you say "drill around the lead joint to help get the lead out" should I drill around the sides of the coupling /sleeve until it loosens? 1/2" bit?
Old 07-02-2011, 11:23 AM   #4
Doing it myself
Alan's Avatar
What i mean by drilling out is drilling down into the lead (between the flange and the pipe.
You're probably going to need to make 30 or more holes before it starts loosening up.
The other option is to heat the fitting up until the lead gets molten and suck it out with a straw, but I'm guessing you don't want to try that one.
Journeyman Plumber
Old 07-02-2011, 12:19 PM   #5
jelly's Avatar
Rewards Points: 330
That was easy, thanks Alan!
Now am I ready to attached the flange with a furnco? Is that it?
Cheers.
Love this forum.
Old 07-02-2011, 01:44 PM   #6
DIY staff
Rewards Points: 7,174
The straw always melts
Alan (07-03-2011)
Old 07-02-2011, 01:49 PM   #7
jelly's Avatar
Rewards Points: 330
I can handle the heating but will leave the sucking up to my wife. BOOM!
The Following 2 Users Say Thank You to jelly For This Useful Post:
Alan (07-03-2011), oh'mike (07-02-2011)
Old 07-02-2011, 05:51 PM   #8
General Contractor
If it were me I wouldn't use a fernco for that situation, besides that I don't see how you could without the flange sitting too high for the floor? I prefer to use a cast replacement flange that has a compression fitting. Slides down onto the original cast pipe with several hex heads that are tightened down creating a tight seal via the compression sleeve built into it, much more solid that way. Just cleanup the outside of the original pipe for a good seal.
dsconstructs is offline   Reply With Quote
The Following 2 Users Say Thank You to dsconstructs For This Useful Post:
oh'mike (07-02-2011), VIPlumber (07-02-2011)
Old 07-02-2011, 09:27 PM   #9
jelly's Avatar
Rewards Points: 330
you're exactly right dsconstructs. I cannot use the furnco because it will sit too high. I will look into the cast flange.
Old 07-02-2011, 09:31 PM   #10
Rewards Points: 16
Wouldn't it be feasible to use a rubber donut?
druminman is offline   Reply With Quote
Old 07-02-2011, 09:38 PM   #11
jelly's Avatar
Rewards Points: 330
is this a rubber donut? how does it work?
Old 07-02-2011, 09:53 PM   #12
General Contractor
http://www.plumbingsupply.com/images...ue-c40-420.jpg
Old 07-03-2011, 11:16 AM   #13
jelly's Avatar
Rewards Points: 330
Thanks all.
I forgot to mention earlier that my waste elbow is twisted. Can I still use the fittings recommended in the posts above?
Old 07-03-2011, 12:58 PM   #14
General Contractor
In that last picture it does look pretty twisted/out of plumb, to where the suggested replacement flange wouldn't work well enough. You definitely want the flange to sit level. If that's the case you may have to cut that cast pipe on the horizontal before the bend and then adapt (fernco) to plastic and go back up from there. If so you'll want to be sure to add your subfloor back in before mounting the new closet flange to make it easier to get your subfloor close to the new waste pipe so that the flange can be secured to the subfloor, otherwise your toilet is going to wiggle around after.
edit to backtrack........oh man, just noticed in the first pictures you have other lines that tie into that horizontal section that would appear to make this advice impossible as well without other modifications. Without standing there to take measurements and a good look at the overall layout I really can't say how I would proceed. It appears as though they originally made up for that twist with the lead filler........any old school plumbers around you?
Old 07-03-2011, 01:03 PM   #15
Doing it myself
Alan's Avatar
make sure BEFORE cutting that the pipe is on grade. It may have fallen down and going opposite grade, which could cause it to be out of plumb like that.
Use a level and make sure you have about 1/4 bubble along the pipe, and you should be close enough.
This is the compression flange that is being discussed : (something along these lines anyway) http://media.mydoitbest.com/imagereq...=2&newsize=600
Journeyman Plumber
Toilet Flange Dilemma (W/ Pics) Rotate Plumbing 5 06-19-2011 06:00 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
cast toilet flange zombie911 Plumbing 4 09-11-2008 08:06 AM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 09:53 PM
