Cast Iron Toilet Flange Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2013, 09:06 AM   #1
Cast Iron toilet flange advice
Hello,
I have gutted my bathroom as part of a remodel and am unsure how to deal with this flange. I would like to remove the flange so I can get the floor decking down but I don't know where I should remove it...
the flange is leaded in and I have seen that that can be drilled out but as you can see in the photo there is a rubber seal (in red box) where I think I could just pull the flange and vertical riser off, seems alot easier then the drilling option. so assuming I go that route what parts would I use to replace the vertical riser and flange? should I put in pvc/abs or stick with the cast? can the rubber seal be reused, if not is there some kind of adapter that is used to convert to plastic pipe at that junction?
Any advice is greatly appreciated.
Wrekdoll is offline   Reply With Quote
Old 09-21-2013, 09:42 AM   #2
Rewards Points: 14,026
If it was mine I'd want to get rid of all the cast iron. At some point it will leak and the insides are by now so rough with rust it may cause it to plug up more often.
With a chain cutter it will snap right off where you want to start the PVC.
Wrekdoll (09-21-2013)
Old 09-21-2013, 10:02 AM   #3
DIY staff
Rewards Points: 7,174
If the hub has a rubber doughnut,as it would appear., wiggle and tap the flange and pipe out of the hub----then get the right hub doughnut for the iron/pvc and change it out to PVC----
Should not be to difficult----just avoid getting to violent and knocking something loose that you don't want to--------
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Ghostmaker (09-21-2013), Wrekdoll (09-21-2013)
Old 09-21-2013, 06:57 PM   #4
Would like to take out all the cast but that is a bit more project then I am willing to take on at this point. Think I will go the donut route. Went and looked for parts at the HD but they had no 3" donuts so I guess it's off to the plumbing supply Monday. Thanks for the direction
Old 09-21-2013, 09:09 PM   #5
DIY staff
Your iron drains are probably fine ,if the picture is typical of the rest of the house---rubber hub connections tell me that the house is not that old----
COLDIRON (09-22-2013)
Old 09-24-2013, 04:57 PM   #6
Yep , checked all the cast fittings I could see and they are similar to that one.
The old flange and pipe came out pretty easily, existing hub seems to still be in good shape, no flaking or tearing. Guess I should probably replace it while I can though...
Rest of the job seems pretty easy except for figuring out how to get a nicely fitted hole in the sub floor at the proper location.
Thanks again!
Old 09-24-2013, 05:59 PM   #7
Rewards Points: 2,042
Measure your center off the back wall and the side wall mark and drill with a hole saw.
Making new plumbing connect to old Cast Iron plumbing fallvitals Plumbing 12 10-13-2012 05:52 PM
closet flange for cast iron pipe tomknox Plumbing 26 01-21-2012 11:05 AM
Leak in Cast Iron? Pipe under toilet... terrapin88 Plumbing 11 11-19-2009 05:54 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
cast toilet flange zombie911 Plumbing 4 09-11-2008 08:06 AM
