Cast Iron Sewer Pipe 1950s - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2013, 05:02 PM   #31
Rewards Points: 14,300
No way would I hire two companys for this one job.
Pretty optimistic thinking this can be in two days.
Time for a vaction?.
Got a buddy that will let you use his camping trailer?
Old 06-23-2013, 09:03 PM   #32
Rewards Points: 208
what type of PVC would you use in a DWV (drain-waste-vent) pipe like the pipes in my crawl space? cell core PVC?
Scully is offline   Reply With Quote
Old 06-23-2013, 09:36 PM   #33
MarginallyQualified
Rewards Points: 2,464
Schedule 40
Old 06-23-2013, 09:39 PM   #34
Plumber
TheEplumber's Avatar
Rewards Points: 904
cell core is for DWV- it will work- the OD is the same as sch 40.
Old 06-23-2013, 09:40 PM   #35
Rewards Points: 208
i read that cell core PVC isn't ideal for sewer pipes because it's brittle?
Old 06-23-2013, 10:03 PM   #36
Plumber
Rewards Points: 904
Haven't heard that- we use ABS cell core, residential and commercial. I guess I got a lot of job security ahead of me changing out pipes.....
Sewer is a term that relates to buried lines outside of the building- not inside. For that I use pvc 3034. It is also used by most municipalities I work with.
For building drains- inside the building I use the ABS cell as pvc is not as common here.
Old 06-23-2013, 10:33 PM   #37
Rewards Points: 208
for my crawl space DWV pipes, you would use ABS cell core?
there's potentially a 6' section of cast iron beyond foundation wall (pic below). for this sewer section you would use PVC 3034?
Old 06-23-2013, 10:46 PM   #38
Plumber
Rewards Points: 904
Here is what my local inspector would want-
ABS or PVC DWV inside the building and at least 2ft outside- then a cleanout installed with the riser brought up to existing grade. Some towns want a 2-way cleanout.
At that point you can then transition the drain to 3034 or keep it ABS/PVC to connect to what is left in the yard. That connection can be made with a Fernco coupling.
ABS/PVC is ok to run out in the yard- all the way to the city stub- it just costs a little more than 3034- some like it better too. But 3034 is not allowed to be brought into the building's footprint
Old 06-25-2013, 10:49 PM   #39
Rewards Points: 208
part of the job is to also replace the cast iron connecting the drains in this section below. my garage has a floor drain which is on the other side of the house separated by a bedroom and breezeway. i wonder if this garage floor drain is also connected? i'm not sure how they did things in the 50s with septic system.
Old 06-25-2013, 10:58 PM   #40
Plumber
Rewards Points: 904
Hard to say but I doubt it. In my area it would have it's own dry well either in the garage floor under the drain- or outside.
Old 06-27-2013, 10:26 AM   #41
Rewards Points: 208
i plan on replacing only a 4' section of the cast iron vent on the first floor. my question is: looking at this picture, is there any chance that it could crack during its partial replacement with PVC?
Old 06-27-2013, 01:08 PM   #42
Plumber
Rewards Points: 904
That section should be in good shape as it's been dry most, if not all of it's life.
3 ways to cut it. Use a sawzall, a grinder with a cut off blade, or rent a pair of ratcheting soil pipe cutters.
If you're super lucky, there might be a hub in the wall that can be broken with a few good whacks using a 2lb. hammer.
The upper pipe is extremely heavy, so be sure it's supported well and doesn't come crashing down on you.
Old 06-27-2013, 06:48 PM   #43
Rewards Points: 2,104
Use a cast iron friction clamp on the stack above where your cutting where it is resting on the upper floor.
http://www.phwarehouse.com/products/...ion-Clamp.html
I think there is a hole in cast iron pipe from toilet cprice Plumbing 5 09-18-2012 08:51 AM
Rusted at thread cast iron pipe handyman99 Plumbing 5 01-24-2012 11:13 PM
cast iron sand pipe Cranky Bait Plumbing 2 03-19-2010 05:52 PM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 06:23 PM
