Cast Iron Sewer Pipe 1950s - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2013, 09:05 AM   #1
Rewards Points: 208
pictures below: 1950s cast iron sewer pipe in crawl space. of course, the house inspector never looked at it when i bought the house. any thoughts? i'm afraid to ask. the previous owner supposedly repaired part of the sewer line that was leaking on land (part of buyer contract).
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 05-12-2013, 09:11 AM   #2
Rewards Points: 13,694
All the old cast and steel drain line will need to be replaced at some point.
100% of the time there going to rust out, leak, or close up on the insides.
MTN REMODEL LLC (05-13-2013)
Old 05-12-2013, 10:51 AM   #3
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Ugh, a real mess there. I replaced mine with PVC, I had moved the toilet and the basement floor drain was just an open cleanout with no trap.
I got rid of the iron where it went to clay tile, and eliminated an old tile floor drain extending from that with a tee that was useless and had tree roots in it too. Put in a new floor drain with a trap, a wye with a plug for cleanout, and concreted back over.
Worst part was the clay tile and having to cut the bell end off to fit the adaptor.
RWolff is offline   Reply With Quote
Old 05-12-2013, 10:58 AM   #4
Rewards Points: 528
Cast drains can last over 100 years/ in fact in my house they have been in for over 100 years.
yes they are rusty looking. If they are not leaking, why replace?
framer52 is offline   Reply With Quote
Old 05-12-2013, 11:13 AM   #5
Rewards Points: 208
cast iron pipes have been used for centuries, right? i don't think mine are leaking...although, i'm not sure if that yellow discharge is rust or gas leaking through.
2 questions:
1. is there any life left in these cast iron pipes?
2. how much would it cost to hire a plumber to replace all of the cast iron visible?
Old 05-12-2013, 12:33 PM   #6
Rewards Points: 3,622
2 questions:
Answer to question #1 probably 40/50 years left.
" " " " #2 You really don't want to know
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 05-13-2013, 09:43 AM   #7
Roofmaster
Rewards Points: 2,210
2 questions:
Hold Your Horses! That cast Iron is in a crawlspace, so the exterior rust you see is probably normal.
I would most definitely replace all the galvanized steel pipe that ties into the cast Iron pipe, but I would probably leave the cast as is. Pull a toilet and take a look inside. If it looks OK, then leave it. The Galvanized steel is another story. It will be full of black gunk by now, especially the line from the kitchen sink. Use your sawsall, or right angle grinder with a thin metal cut off blade, cut it our and replace with PVC DWV. Tie in with fernco couplings, right near the cast Iron. The galvy Vents can stay, just make sure the pipe is properly supported.
The Following User Says Thank You to jagans For This Useful Post:
Old 05-13-2013, 10:09 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 664
Good suggestion Jagans. 2 points that concern me though:
1.Whats the drip stain on the right side of the foundation- cracked pipe?(1st picture)
2. The close nipple at the 45 is probably the weakest link since its mostly exposed threads, they tend to rust out quickest. (2nd picture)
Old 05-13-2013, 08:11 PM   #9
Rewards Points: 208
TheEplumber, i think that drip stain on right foundation is rust because that pipe connects to the utility/laundry room, which is on the other side of the bathroom. See additional pictures above.
what would you guys suggest i do?
Old 05-13-2013, 08:15 PM   #10
Rewards Points: 582
its time to replace it ....look at the cracked hub at the bottom wye and cleanout...sorry ben sr
Old 05-13-2013, 08:34 PM   #11
Roofmaster
Yeah I think You may be right Ben. I just took a good look at photo 5, and it appears that water is weeping right through that elbow.
Great Photos by the way, Scully. Sorry for the bad news, but not really that expensive to replace, thanks to Plastic. Just imagine if you had to do it in CI again?
ben's plumbing (05-14-2013)
Old 05-13-2013, 08:40 PM   #12
Rewards Points: 208
2 questions to all:
1. how much would it cost to hire a plumber to replace everything i see in that crawl space?
2. should i be concerned about the pipes beyond the foundation?
Old 05-14-2013, 12:30 AM   #13
747
registered
747's Avatar
Rewards Points: 534
A plumber is going to hurt your feelings. Its a bust your ass job for him. I would think at least 5K. I bet i'm in the ballgame. Get some bids.
747 is offline   Reply With Quote
Old 05-14-2013, 06:18 AM   #14
DIY staff
Rewards Points: 7,174
Best to call a local Plumber----I see a day for a plumber and a helper---
I see you are in Wisconsin---prices vary across the state---so make a call or two---Mike---
Doing that your self will cost about $100 in parts and $25 to rent a chain breaker for the iron pipe.
Old 05-14-2013, 07:00 AM   #15
Master Plumber
Javiles's Avatar
Rewards Points: 996
Thats what you see, now consider what you cant see, vent stacks waste arm arms etc, how far down the main will you need to go ?
you'll need to get a plumber out to look at everything and not sugar coat anything. get at least three quotes and never go with the cheapest.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
I think there is a hole in cast iron pipe from toilet cprice Plumbing 5 09-18-2012 08:51 AM
Rusted at thread cast iron pipe handyman99 Plumbing 5 01-24-2012 11:13 PM
cast iron sand pipe Cranky Bait Plumbing 2 03-19-2010 05:52 PM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 06:23 PM
