Old 03-16-2010, 12:14 PM   #1
cast iron sand pipe
I have an old building where they ran shielded electric conduit along the cast iron pipe. I heard the current and the galvanized conduit will cause the cast iron pipe to get rust holes where the conduit is resting against the pipe. I have a 6 inch hold I need to repair. What is the best method and if I cut out the pipe what are the chance of the pipe above me will come crashing down. This maybe a project to big for my skill level.
Cranky Bait is offline   Reply With Quote
Old 03-19-2010, 02:16 PM   #2
cast iron sand pipe
If you are a real handy guy you can get a clamp at plumbing supply and anchor the pipe so it wont slip down. cut out bad section and replace. If that is above your skill level I would reccomend an experienced service plumber not a new construction plumber
plumberinlaw is offline   Reply With Quote
Old 03-19-2010, 06:52 PM   #3
cast iron sand pipe
You might be able to get a new clamp section to put right over the defective area to good metal with out cutting. I'd look around before I cut that cast.
COLDIRON is offline   Reply With Quote
Tags
cast iron sand pipe
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 08:41 PM
Cast Iron Pipe ehv8trix Plumbing 4 11-25-2009 07:49 PM
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 5 08-21-2009 09:44 PM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
