-   -   cast iron questions (well not the questions) (http://www.diychatroom.com/f7/cast-iron-questions-well-not-questions-152081/)
petros151 07-31-2012 01:43 AM
I have to cut into Cast Iron and insert a PVC sanitary tee connection for a sink drain to go into.
what do I need to do b4 I cut to minimize sewage coming out (should have have a big bucket ready? ) and then what about the gas if any gas leaks out. It may take me several hours to complete the task of getting a PVC sanitary tee fit into the cut area hate to have any explosions or pass out from gas :eek:
can I also use this time to clean out the rest of the cast pipe? if so what should I do ? chimney sweeps brush and water ? :laughing:
finally I assume I get the 4" S-tee put stubby 4" PVC pieces on the ends and then cut cast so it butts up to the stubs and firnco those joints ... yea? :thumbup:
oh'mike 07-31-2012 07:02 AM
Water coming out? --Don't let anyone flush toilets or use sinks while you work---
Gas? Cloths pin on the nose?:laughing:
Don't try cleaning out the pipe like you described---you could clog the lateral line with the crud you dislodge---for cleaning--use a power rodder--(and a pro to operate it?)
Rent a chain breaker to cut the iron----neat,five minute job---
Be sure the iron is properly secured before cutting---Falling iron drains can change your life forever.
petros151 07-31-2012 09:52 AM
the local rent place has a manual chain cutter u were saying a 5 min job I assume with the newer hydrolic one?
The guy said "it's a real pain to use this thing" :( so am I getting into trouble if I try this manual one? Don't want to pay for it and then find out I will not be able to do it. He said no one in the area rents a hydrolic. I should mention I have about 3" of clearance in back of the pipe.
as far a support I see I need to strap it right near the cut site, what's the best way to strap to a floor joist these are above it maybe 24" ?
thanks!
TheEplumber 07-31-2012 10:09 AM
199 Attachment(s)
I use what we call ratchet cutters. Same as what Mike refers too. They are not hydraulic and are not a pain to use-- well, maybe for a newbie :)
Two other options are sallzall or cut off blade in a grinder.
As for supporting the pipe. get a 4" IP riser clamp, attach it about a foot above your work and support it to the ceiling or post up from the floor.
petros151 07-31-2012 10:23 AM
can you post a pic of the ratchet cutter? I have a 4" pipe and a search on that showed up the small pipe cutters I have for copper 1" pipe
is it the same as those copper cutters but bigger?
no one has one for rent here how much are they to buy ? and where ?
thanks!
Alan 07-31-2012 10:28 AM
thanks!
They are expensive, and nothing like a copper cutter.
http://www.ridgid.com/ASSETS/7F2D1C9..._Cutter_3C.jpg
petros151 07-31-2012 10:35 AM
ok this rental guy said it was a "chain cutter with cutting disks inbetween each link" so that l;ooks like what you guys are talking about
if it's not that hard to use I"ll try it -- any advice? my pipe has 3" of clearance behind it looks like that is enuf
petros151 07-31-2012 01:01 PM
I got this chain cutter he said it shatters the pipe I thought you spin it around like a copper pipe cutter but no it's stationary --- first time doing this it sounds like the pipe could crack and you could get all kinds of uneven breaking
does this thing really work?
TheEplumber 07-31-2012 01:16 PM
199 Attachment(s)
Search YouTube. They show it in action.
Vertical pipe is a little tougher to get positioned but if you have good pipe it's a snap
Sent from my iPhone using DIY Forum
petros151 07-31-2012 01:43 PM
ok I got horizintal pipe and I got two *very clean* cuts! :thumbup:
BUT the piece is still sitting in there!!! How do I get it out without damaging the rest of the pipe ? I hammered a it but it really rattled the rest of the pipe alot... :eek:
thanks!
petros151 07-31-2012 03:06 PM
I'll answer my own question what I did was to crack the pipe again inside the cut points and then took a chisel and carefully chipped out some pieces until the center came loose. That process was 100% harder than using the ratchet cutter! The snap cutter (ratchet cutter) is easy as pie one cut took 30"
:thumbsup:
