Cast-iron To PVC Banded Coupling - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2007, 01:17 AM   #1
Rewards Points: 1,062
Question
cast-iron to PVC banded coupling
is it okay to use the same black clamped banded coupling for cast-iron to PVC as it is used PVC to PVC ? the kind you see all over the place and can be found at any hardware store.
i just dug down to where there is a PVC hub mounted on cast iron and i want to replace the hub but the existing couplings have, on top of the rubber, an additional ribbed metal band (between the rubber and the clamp bands). as the metal band makes it look a little sturdier, i was wondering that the regular aforementioned type may not be strong enough.
input appreciated.
thanks,
- a
Old 07-14-2007, 03:02 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
What you're describing is known as a Fernco coupling (solid neoprene rubber) and a Mission or no-hub coupling (with a stainless steel sleeve). Fernco and Mission are just brand names of course.
Use the no-hub coupling for PVC to cast iron.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Cast Iron Baseboard Installation Bob G. HVAC 7 09-15-2009 09:22 AM
cast iron tub removal help frogger Building & Construction 37 12-01-2008 03:31 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 08:09 PM
Old cast iron pipes heather92 Plumbing 2 04-10-2007 09:36 AM
