Old 08-07-2009, 03:45 PM   #1
Cast iron to PVC
I have a concrete floor with 2 inches of 4 inch cast iron sticking up. I need to immediately go to a PVC 4 inch sanitary "T". I cant use a coupling as I wont be able to get the drain slope right so I need to adapt the PVC socket to the 4 inch cast. Is there a method of doing this? In other words, I would like to slip the socket over the cast iron. I need to come out of the "T" as close as possible to the floor.
TryTibbs is offline   Reply With Quote
Old 08-07-2009, 04:29 PM   #2
Cast iron to PVC
cut the concrete around the pipe out and properly install a fernco coupler... do it right now, and you wont have to clean up leaking sewage later.
I did have a similar issue where the waste line going through the footer broke off with only about an inch to spare. I secured new pvc with some marine grade putty epoxy, and encased it all with cement... couldn't really think of any other solution besides digging up outside.... nooo thanks. few years later, no issues.
johnnyboy is offline   Reply With Quote
Old 08-07-2009, 10:36 PM   #3
Cast iron to PVC
cut the concrete open and connect onto the cast lower with a nohub band. anything else and you are begging for a leak.
plumber Jim is offline   Reply With Quote
Old 08-08-2009, 12:40 AM   #4
Cast iron to PVC
Went to the fernco website and found a hubless 4 inch sanitary T.
Old 08-08-2009, 02:45 AM   #5
JDC
Plumbing Contractor
JDC's Avatar
Cast iron to PVC
Install a 4" street tee with a 4" plastic X cast iron proflex coupling (by fernco). That should get you to where you need to be.
JDC is offline   Reply With Quote
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
Porcelain Quality on Steel and Cast Iron Tub? MrTubz General Discussion 5 03-04-2009 06:24 AM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 11:58 AM
