Cast Iron To PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2008, 04:46 PM   #1
cast iron to PVC
when removing my bathtub the old cast iron trap broke so I decided to replace with PVC. I used a rubber fitting and hose clamps to attach the to together. Should I have used epoxy to seal the rubber fitting to the cast iron and PVC or will the hose clamps be ok? I tested it and there was no leaks, but I want it to hold up in the long run. here is a picture of the job.
Jone is offline   Reply With Quote
Old 12-11-2008, 05:22 PM   #2
bradnailer's Avatar
As long as you have good alignment, the way you made the transition should be just fine.
bradnailer is offline   Reply With Quote
Old 12-11-2008, 08:12 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
A no-hub coupling would probably have been better, but you used so many clamps that you almost made one anyway. LOL
What you did should work.
Mike
Mike Swearingen is offline   Reply With Quote
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
How are cast iron drains? Do you have to plunger them often? twilightcall Plumbing 4 08-29-2008 12:07 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
