Cast Iron Problems Please Help. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2012, 11:41 PM   #16
Bombastic Idiot
notmrjohn's Avatar
Jay, its just the first picture I found, you know, just to sorta give the general idea. Besides maybe the OP is like really, really strong, he does climb cities after all..
thumbs, according to jay, if you try to use and hold the one I posted up in the air, its both.
notmrjohn is offline   Reply With Quote
The Following User Says Thank You to notmrjohn For This Useful Post:
jaydevries (09-16-2012)
Old 09-17-2012, 12:30 AM   #17
I use all the time one of those chain cutters like this one, but even bigger and heavier:
http://www.ridgid.com/Tools/206-Soil...r/EN/index.htm
They are extremely handy, i bought a very old one on ebay for $120 I think some time ago, and is such a great tool to have.
Only one advice: when you cut any pipe, but specially when you cut anything over your head, DON'T FORGET SUPPORT it properly, I still remember the 1st time I used this tool, I was in the basement, I cut a 4' 4" cast iron pipe with a hub connected at the top to the flange of an old toilet (that I did already remove), then when I cut the pipe (it is literally a snap to cut any cast iron pipe, so easy!), and all that pipe and flange went down throught the subfloor (was an old 100 years old house) and hit me on the side of the head (luckily I was wearing my hat) and knock me off and I was a whole minute barely able to move after that. Nothing else happened to me, I was lucky. I had to patch the hole I did to the subfloor, and since then I'm very careful when I work with the iron pipe cutter. :-)
Pirulo is offline   Reply With Quote
Old 09-17-2012, 11:51 AM   #18
Bombastic Idiot
notmrjohn's Avatar
Pirulo has completely recovered from the blow to the head, the daily commute from his home in Alberta to his job in Kansas doesn't bother him in the least. well, he does have a bit of a problem determining which toilet to work on, since all the bathrooms he's worked on since then have a matched pair, But when he reaches for a Stillson he seems to always pick up two, so it all works out.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
Old 09-17-2012, 12:55 PM   #19
I've never been in Kansas, you should be confusing me with some other guy, but yes I live in Alberta. About the Stillsons, yes, normally use them by a pair, it makes working with iron pipe much easier About the iron pipe falling in your head, man those are so heavy that a subfloor can't support them. Have a great day.
Old 09-17-2012, 05:46 PM   #20
I did not think it was a good idea to use a chain cutter on a hub when you want to use the pipe inside of it.
1950home is offline   Reply With Quote
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 03:42 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
Kohler vs. AS cast iron bathtubs? VinDan Plumbing 5 07-31-2010 01:48 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
