-   -   Cast iron problems please help. (http://www.diychatroom.com/f7/cast-iron-problems-please-help-156799/)
thecityclimber 09-14-2012 12:48 PM
3 Attachment(s)
I Replaced a section of my mainstack about two weeks ago with PVC and two 4" fernco's. The problem is the old pipe was so bad that that their was only about an inch left of pipe before the bell ,to attach the fernco too. The top one started leaking today. I'm wondering if I can unscrew the bell part instead of cutting all the pipe out? I really really Don't want to cut all the pipe out.
thecityclimber 09-14-2012 01:22 PM
I just tighten the screws up with a socket wrench instead of a flat head screwdriver and they are much tighter now. Maybe the fernco was just lose?
antinusk 09-14-2012 03:59 PM
That bell part doesn't unscrew. You have to chisel out the lead and pull out the oakum- rope-fiber like stuff.
Then the bell just slips off.
If you get the more expensive fernco connectors from the plumbing supply, they have a metal sleeve over the rubber and a few more clamps.
They work really well.
Maybe you can get away with adding another hose clamp too
allthumbsdiy 09-14-2012 06:47 PM
The product is called Fernco Proflex.
It has a full metal sleeve which I believe allows greater distribution of the force when you tighten up the ring
thecityclimber 09-14-2012 09:37 PM
Thanks for the info guys I'll check out the other model And change it out. I appreciate the replies.
We just bought this house and it's with out a doubt a fixer upper. Thanks again.
Alan 09-14-2012 09:41 PM
IF you really felt ballsy, you could bust that hub off of the fitting. Underneath it you will find a pipe end that you can attach pvc to.
I've done it lots of times, but you have to be careful and only crack the hub. If you get too rough with it, you could bust the fitting and then you're in real trouble.
TheEplumber 09-14-2012 09:47 PM
199 Attachment(s)
Did this today :thumbup:
Backed up the back side of the hub with a 2lb. hammer and smacked the front with another hammer. Works slick, but use caution :thumbsup:
allthumbsdiy 09-14-2012 09:49 PM
is there a special "cracking" tool?
Alan 09-15-2012 09:42 AM
http://i.pgcdn.com/pi/76/85/95/768595429_260.jpg
allthumbsdiy 09-15-2012 10:03 AM
Originally Posted by Alan (Post 1010315)
thanks.
I had just read in my latest Family Handyman issue about a "nut splitter" and was wondering if there was a similar tool for this situation (http://www.familyhandyman.com/DIY-Pr...View-All#step9)
BTW, I wonder why they don't make that ribbed handle for a regular hammer.
1950home 09-16-2012 05:55 AM
With only having an inch to clamp on to you need to remove the bell.
I found the best way to separate cast iron joints is to drill out as much of the lead and rope. I'm thinking it was 3/8” bit and be ready to snap one or 2 when your at it. The rest you will need to chisel out.
From the pic I would.
I have also used a 4” angle grinder to remove a section of the hub. Then you should be able to use a large hammer to spin / knock it off the Y. If you can get it to spin then cut another chunk out of the hub.
notmrjohn 09-16-2012 08:53 PM
1 Attachment(s)
"cracking" tool Yeah, don't know how well it would work on that short bell or what it would do to fitting underneath. you can rent one if the experts here trust you with it.
ribbed handle for a regular hammer. don't know what a 'regular' hammer is , one mans regular hammer is anothers framing hammer, or masons hammer or welders no spark brass, or..... well, all kinds of hammers have all kinds of handles. I don't think I'd want that ribbed handle on claw hammer myself, another man might, because one man's... we already been there.
Big box has Fernco Proflex as does local hardware. Don't need to go to your fancy high falutin plumbing supply:whistling2: may have to go there to get fancy rib handled irregular hammer.
jaydevries 09-16-2012 09:21 PM
wow i would like o see someone use that style of snapper in the air i would try one of these for that
http://www.ridgid.com/Tools/Soil-Pip...2/EN/index.htm
Javiles 09-16-2012 09:28 PM
Get in there with a grinder like a makita with a steel cutting wheel cut the hub as far apart as possible remove the cut section remove the oakum and lead and there is the base of the tee, now that may have a small lock lip on it as well. but easier to work with.
allthumbsdiy 09-16-2012 11:24 PM
you "crack" me up notmrjohn :)
btw, isn't that a pipe cutter, not a "nut cracker"? (pun intended)
