Cast Iron Pipe Broken? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2009, 05:36 PM   #1
Cast iron pipe broken?
I have started a basement bathroom project that involves moving the stub for a tub drain into the center of the space and putting in a shower drain instead. I have broken out the concrete slab and discovered that the cast iron pipe under the slab appears to be cracked/broken. The pipe appears rusted and bulged and is moist. I believe the toilet in this bath joins the same pipe roughly 3 to 4 feet away. Does it seem reasonable to think I need to break up the slab to the vicinity of that joint and replace the whole section? Is there any way to seal the pipe without removing it? (I think I'm grasping at straws there!) I thought about trying to cut the pipe further up, but I'm afraid that it all may be weak and crumble. Seems strange to find this pipe damaged - the house is only 25 years old, the pea gravel under pipe seems normal.
tervic is offline   Reply With Quote
Old 02-18-2009, 12:30 AM   #2
I cannot see the pipe, but it sounds bad to me. Since you are changing from a tub to a shower, you may as well dig up the pipe and make it to code. Tub drains are 1-1/2" and shower drains are 2" per code.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-18-2009, 01:28 AM   #3
Cast iron Pipe Broken.
There is a way to seal the cast iron but in the long run, it is going to leak.
It is better to cut the ugly portion, and make a connection to black PVC of the same size using a neophrene gasket at both ends to tighten the joints. It is easier said than done, especially that you have the concrete.
Good Luck.
Gabriel24 is offline   Reply With Quote
Old 02-18-2009, 10:01 AM   #4
MasterPlumber
ironrange's Avatar
It's always been code that ANY pipe buried underground or under a slab is to be 2" minimum no matter if it's a tub or not.
ironrange is offline   Reply With Quote
Old 02-18-2009, 01:34 PM   #5
Thanks for the replys. I'm going to do some more digging (literally!) this afternoon and I'll report back about I find.
Old 02-18-2009, 05:49 PM   #6
Ironrange. I have installed many 1-1/2" pipes under slabs for houses. You may be talking about a certain areas code, but in Florida, we ran all the lines under the slab and not all were 2". I have also seen the rough-in piping here in Arkansas with the same thing.
Old 02-18-2009, 07:23 PM   #7
MasterPlumber
ironrange's Avatar
Yes, I was refering to the plumbing code here in Mn., minimum 2" always.
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-18-2009 12:18 AM
Loosening bolt on cast iron pipe kegger42 Plumbing 2 09-24-2008 12:12 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
