Cast Iron Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2008, 06:38 PM   #1
cast iron flange
Trying to track down a leak from our bathroom, I ended up removing the toilet and surrounding floor down to the floor rafters. Discovered a pretty rusted and messed up iron flange apparently screwed on to the 4 inch waste pipe. All replacement pvc flange packages including the "Super Flange" brand said to first remove the old flange. Rigged a device to try to unscrew the rusted flange but couldnt budge it. Right now the old flange is abt 1/2 inch above the floor level.
First, what's the trick to unscrewing the old flange and, second, if I cant get it off, will the addition of a super flange on top create too much height for the toilet? Cant really raise the sub floor either. Appreciate your suggestions.
Jrebhun is offline   Reply With Quote
Old 09-05-2008, 09:45 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Good luck unscrewing the old flange. You'd be one of the few I'd ever know to be able to do such.
I've used a 4" angle grinder with a metal cutting wheel before to cut the old flange off. Might consider that. Don't forget safety glasses and a good dust mask.
Old 09-06-2008, 12:45 PM   #3
Most cast iron flanges are held on with lead that has been melted and poured into the space between the flange and the pipe. The Super Flanges I have seen are installed over the existing flange (even broken ones) and screwed to the floor. Only about 1/16 to 1/8" thick.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
How are cast iron drains? Do you have to plunger them often? twilightcall Plumbing 4 08-29-2008 12:07 AM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 07:40 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
