Cast Iron Drain Pipe Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2012, 12:45 PM   #1
Cast iron drain pipe replacement
My basement drain pipe is leaking. I want to replace the cast iron section with PVC. The pipe currently abuts to PVC 5 feet down the pipe already. How do I best cut the cast iron?
riedej is offline   Reply With Quote
Old 05-09-2012, 12:52 PM   #2
There is a special tool for cutting cast iron .. it looks like a metal handle with a bicycle chain on it. Be careful when cutting cast iron, as you still have to support the VERY HEAVY piece that's left hanging behind!
leonki is offline   Reply With Quote
Old 05-09-2012, 12:54 PM   #3
What tools do you have that you think you could cut it with. You may be better off to pay a plumber who has one of those chain type cutters than spend money on tools. If you want a sore arm a hacksaw does work. Otherwise they make reciprocating saws or grinders with the proper blades work but none will be as nice as the cut you get with the special tool.
bill01 is offline   Reply With Quote
Old 05-09-2012, 12:56 PM   #4
Owner
LateralConcepts's Avatar
Cast iron piping can be cut with either a grinder or a tool referred to as a "snap cutter", "chain cutter", or "chain snaps".
CAUTION: Cast iron however, is extremely heavy and must be supported prior to cutting out a section. If you're referring to a vertical section (4" cast iron stack that runs through the roof). It must also be supported with a clamp on the roof.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
jaydevries (05-09-2012)
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
