Cast Iron Drain Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2009, 09:37 PM   #1
cast iron drain pipe?
In the process of bathroom remodel and am going to change over the pipes (there was a leak that caused remodel). Main pipe runs from the second floor bathroom through the kitchen into the basement. The plumber want to replace cast iron pipes with PVC. With to the placement of the pipe throughin the kitchen (I understand PVC is much louder than cast iron, even with insulation) can I run a cast iron pipe through the kitchen and all others PVC?
thanks
sharp is offline   Reply With Quote
Old 10-13-2009, 11:16 PM   #2
Yes, you can run new cast iron for a stack and do pvc on the rest. The cast is quieter.
plumber Jim is offline   Reply With Quote
Old 10-14-2009, 06:44 AM   #3
Thanks for the reply.
Old 10-14-2009, 11:52 AM   #4
Sure you can. You can go to cast iron that is connected with No-hub couplings which means no lead joints.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 06:23 PM
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
