Cast Iron Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2013, 08:08 PM   #1
ScottFla40's Avatar
Doing a bathroom remodel and when I chipped out the mortar bed & exposed the drain I noticed that the pvc drain seemed to be just resting on top of the cast iron drain pipe. Before I can move forward can someone please give me some advice on how to connect new pvc drain to cast??.. Thanks..
ScottFla40 is offline   Reply With Quote
Old 06-30-2013, 08:39 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 900
Are you talking about a toilet?
Old 06-30-2013, 09:08 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ScottFla40 View Post
....how to connect pvc to cast??
A rubber compression coupling.
Lots of sizes and types to choose from LINK
Old 07-01-2013, 11:02 AM   #4
ScottFla40's Avatar
No. Shower drain is cast.
Old 07-01-2013, 11:04 AM   #5
ScottFla40's Avatar
I seen these. I am just concerned about clamps rusting or rubber dry rotting...
Old 07-01-2013, 12:12 PM   #6
Plumber
Rewards Points: 900
These are code approved- tried and tested
The bands are stainless steel and the neoprene will not rot.
Use a 5/16 nut driver to tighten to 60 inch lbs.
Old 07-02-2013, 12:19 PM   #7
ScottFla40's Avatar
Got the compression coupling in place.. 1 problem... Drain sits too high by about 1-1/2".
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 02:17 PM
Cast iron drain pipe jburd964 Plumbing 3 01-25-2013 04:38 PM
Putting PVC to cast iron tub and pipe Jamason Plumbing 2 03-26-2012 06:39 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
