Old 01-25-2013, 04:57 PM   #1
jburd964's Avatar
Cast iron drain pipe
What's the easiest way to remove lead from 3" drain pipe without damaging female connection? Without burning rig. My bottle is empty.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 01-25-2013, 05:04 PM   #2
Not sure why you would want to. Just snap it off with a chain cutter you can rent. A 4-1/2 right angle grinder or a sawlsall with a carbide blade will also work, Might take all of 5 min. and leave a nice smooth cut then just use a hubless connector.
Old 01-25-2013, 05:26 PM   #3
funfool's Avatar
sawzall with a metal blade will do it also, trick is to slow the speed of the sawzall, mine has a speed control switch. Is normally on 6, for cast iron use a metal blade and turn the speed down to 3.
I have seen my plumber come in with a old used metal blade and cut out every cast iron pipe in a house he could get to, and blade is still good for the next job.
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
Old 01-25-2013, 05:38 PM   #4
call me E
TheEplumber's Avatar
If you want to remove the lead- use a 1/4" drill bit. Drill several holes into the lead around the circumference. Pry out whats left with a screw driver. Now you should be able to wriggle the pipe/fitting out of the oakum.
sorry for the small image
Is there a longer bath tub drain flange? Lined cast iron tub. kokobeans Plumbing 0 11-18-2012 10:56 AM
Leaking drain pipe under kitchen sink dethun Plumbing 20 09-26-2012 08:30 AM
Putting PVC to cast iron tub and pipe Jamason Plumbing 2 03-26-2012 07:39 PM
Sealing drain to cast iron receptor Lockeset Plumbing 7 11-15-2010 09:48 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
