-   -   Cast iron drain pipe (http://www.diychatroom.com/f7/cast-iron-drain-pipe-170108/)
jburd964 01-25-2013 03:57 PM
What's the easiest way to remove lead from 3" drain pipe without damaging female connection? Without burning rig. My bottle is empty.
joecaption 01-25-2013 04:04 PM
Not sure why you would want to. Just snap it off with a chain cutter you can rent. A 4-1/2 right angle grinder or a sawlsall with a carbide blade will also work, Might take all of 5 min. and leave a nice smooth cut then just use a hubless connector.
funfool 01-25-2013 04:26 PM
sawzall with a metal blade will do it also, trick is to slow the speed of the sawzall, mine has a speed control switch. Is normally on 6, for cast iron use a metal blade and turn the speed down to 3.
I have seen my plumber come in with a old used metal blade and cut out every cast iron pipe in a house he could get to, and blade is still good for the next job.
TheEplumber 01-25-2013 04:38 PM
199 Attachment(s)
If you want to remove the lead- use a 1/4" drill bit. Drill several holes into the lead around the circumference. Pry out whats left with a screw driver. Now you should be able to wriggle the pipe/fitting out of the oakum.
sorry for the small image
