I just brought a house once the heat was turned on we found that there is a leak in the front room cast iron baseboard radatiors. 12 fee, How can we fix this. Do we need to replace the radatiors.
If it is leaking at a connection, joint, or where there is a plug, that can probably be repaired. If at a spot where there is no connection or joint, not good. There are ways to fix things like that, but they are often only temporary fixes.
My plumber said that I need to replace the two cast iron radiators in the front room due to the leak, but to get the 24 inches that will cost me $1,500. However, we do not know if there are any other leaking radiators, because there is not shut off for the front room. He will have to fix those first and move on to see if there are other cast iron radiators that are leaking. He said I could go with cooper, which is cheaper, but I will need to change all the rooms and the basement to cooper. My question is would i also need new piping if i switched from the cast iron to the cooper? The front room and the kitchen are both about 24 inches. The bed rooms are about ten inchen and the basement also. The bath are about 4 inches. Can anyone tell me how much it would cost me to replace them all with cast iron, or to replace them all with cooper?
Does anyone know where i can find in Chicago, cast iron radiators for under $45.00 a foot?
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
