Cast Iron To ABS? (or Pvc) - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 09:46 PM   #1
analogmusicman's Avatar
Rewards Points: 560
cast iron to ABS? (or pvc)
ok,so here is my project: I'm putting in a "half bath" downstairs and of course need a drain for the toilet. so,the plan is to open the concrete floor and put a "Y" into the drain pipe. only thing is,that drain pipe that goes under the concrete is cast iron. (a plumber told me that right about when this house was built in '79, builders went from cast iron to pvc in the concrete, mine must have been one of the last houses built with cast iron pipe) there shouldn't be a problem cutting the pipe (my recip. saw cuts everything!) but I imagine that the "Y" has to be cast iron,right? how do you attach it? glue? NAH! and will the pipe have to be cast iron all the way to the flange? (probably 4-5 feet)
tnx,
analogmusicman is offline   Reply With Quote
Old 01-27-2012, 09:54 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
You can cut the cast with a carbide coated sazall blade and use a fernco connector. The fernco will be either a 4" cast to plastic or a 3" cast to plastic. Attach the fernco to the cast and run plastic the rest of the way. The pipe in the picture looks like 3" ABS and if the cast under slab is 4" get a 4" cast to plastic fernco. Then get a 4x3 pvc bushing and install the bushing in the fernco plastic side then run 3" from there
Also, find the carbide blades because a regular metal cutting blade won't do it. If you have a plumbing friend that has a snap cutter for pipe use that.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
ben's plumbing (01-29-2012)
Old 01-27-2012, 10:59 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
PVC is ok for the tap, I recommend that you use no hub couplings and no hub adapters for the mating,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-28-2012, 12:36 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Depends on how your inspectors are and your local codes.
I cant imagine them having any problem with you using a cast iron wye and no hub coupling and a wye,once it leaves the wye you can run the branch line in pvc
plummen is offline   Reply With Quote
Old 01-28-2012, 10:16 PM   #5
Rewards Points: 560
so, I guess we've come "full circle" back to my original question about how one would attach a cast iron "Y". hot lead? does anyone do that anymore? (I saw a plumber do that years and years ago to the cast iron sewer pipe in my parent's house) do plumbers just use "clamp on" type couplings nowadays?
tnx,
Old 01-28-2012, 10:21 PM   #6
Rewards Points: 560
I haven't come across any code that doesn't allow for PVC. Why in the world would you want to bury a metal fitting or pipe? If you follow what I suggested it will pass code and you will be fine.
Pouring lead has almost become a thing of the past. With all the advances in plumbing cast is a thing of the past in residential plumbing.
Also, keep in mind that over years the waste will deterorate the inside of cast and can cause areas to catch debri and it flows out where as PVC doesn't.
Old 01-28-2012, 11:03 PM   #7
Rewards Points: 560
I guess it's just my dumb old curiosity but I'm wondering...if you look at the pic, how was the lower piece of "cast" attached to the wide "joint" going into the concrete? could that be lead or some other "stuff"? just wondering...
tnx,
Old 01-28-2012, 11:16 PM   #8
Rewards Points: 560
The hub above concrete has a rubber do-nut to attach ABS, going through the concrete it either goes straight down to a bend or bends as it goes through the concrete. I assume is is lead at the next hub.
Old 01-29-2012, 08:04 AM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 996
Itís very simple get your pvc wye get 2 no hub adapters 2 no hub couplings, glue the 2 no hub adapters to the wye measure it, then cut the cast iron so that the new pvc section fits with about an 1/8Ē clearance on each end. Clamp it in place with the no hub couplings do use fernco in this situation, youíre asking for problems by using ferncos . you can now continue in PVC. this is a code approved tap.
Old 01-29-2012, 09:57 AM   #10
plummen's Avatar
tnx,
No hub couplings would be my choice,although i still pour a lead joint once in a while
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
Old 01-29-2012, 01:35 PM   #11
Rewards Points: 560
Just an old retired hack from nebraska with 30 years and several diffferant master plumbers licenses ,a master electricians license and an electrical contractors license who apparently knows nothing
don't be so hard on yoursef "plummen"! just remember,as an old "sage" once said:
"noone is totally useless,he can always be used as a bad example"
Old 01-29-2012, 04:49 PM   #12
plummen's Avatar
Oh dont worry no doubt in my mind that I can wire/plumb and dig holes as well anybody,just not as fast anymore is all!
Old 01-29-2012, 05:12 PM   #13
Rewards Points: 636
use a pvc wye same size as cast then you can reduce new branch to 3" if wanted to save cost the wye will be attached to cast with disimbler bands they are the ones with the smooth stainless shield cast can be cut with sawzall blade for cast, or grinder, or rent a cast snapper which is best option
jaydevries is offline   Reply With Quote
Old 01-29-2012, 05:18 PM   #14
plummen's Avatar
Is that legal in your area to mix/match materials before a branch line?
Old 01-29-2012, 05:38 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 832
I can install a wye of any approved material as long as the proper transition couplings are used.
If I'm following this thread correctly, I'd cut an ABS wye into the bldg. drain and connect it using a PLxCI no-hub. Then run ABS to the existing ABS stack.
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
