Cartridge Stuck In A Kohler Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2009, 07:49 PM   #1
Cartridge stuck in a Kohler faucet
I'm trying to fix a leaky faucet in my bathroom. The hot water cartridge is stuck. I pulled out the cold water one from the handle to check it and I didn't have any problems but I can't budge the hot water one. What can I do?
Fan in Exil is offline   Reply With Quote
Old 05-14-2009, 10:27 PM   #2
They make a cartridge removal tool that you can purchase at your local plumbing store. Check with a neighbor who is handy at plumbing, maybe he might have one.
myworkshop is offline   Reply With Quote
Old 05-15-2009, 06:29 AM   #3
All you need for it is an extra deep socket which I have. I got the cold water one out with no problem. This one seems to be rusted in or stuck or something like that.
Old 05-15-2009, 06:34 AM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
The cartridge removal tool isnt for taking the nut off. It screws into the stem of the cartridge and assists in pulling it out. Sometimes cartridges are a real PIA to remove. A Moen rep told me to spray hairspray on their cartridges if they are stuck. Apparently the hairspray shrinks the rubber seals enough to get them to break free. Perhaps this will work with Kohler...not sure. Sometimes you just have to get "Rambo-ish" with them and yank them like a tooth with a pair of channel locks.
JDC is offline   Reply With Quote
Old 05-15-2009, 08:47 AM   #5
There is no nut for this, because the cartridge itself is threaded and screws into the base. So all you need is a socket wrench because once it's unscrewed the entire cartridge is coming out. I've been going as Rambo on it as I can and apart from yanking the entire sink away from the counter top I've got nothing.
So if anyone has any thoughts about how to do something to clear out the grime that would be great, or some other way to break it lose without breaking the sink.
The Following User Says Thank You to Fan in Exil For This Useful Post:
Larrywick (12-21-2011)
Old 05-15-2009, 11:53 PM   #6
I blame ProWallGuy
Rewards Points: 150
Peek chure is worf 1000 wurds.
Double A is offline   Reply With Quote
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 25 01-26-2014 05:31 PM
cartridge faucet problem. drewhart Plumbing 4 01-15-2009 10:49 AM
shower faucet Cartridge leaks Dragontat2k Plumbing 2 05-21-2008 03:16 PM
Kohler Coralais Faucet Repair Steve VA Plumbing 2 09-04-2007 10:01 PM
