Is Cartridge Replacement The Fix? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2012, 11:51 AM   #1
Is Cartridge Replacement the Fix?
Our downstairs shower head runs when running water in other rooms.
Specifics: Kohler single handle. Leak increases to steady stream as water flow increases in other rooms. No leak or drips otherwise. With no other rooms running water the valve seems to function without issue.
Installed in January 2008. Very rarely used (couple times per year). Noticed leak in 2009. Have recently finished rest of the basement and now want to stop this issue.
duffin is offline   Reply With Quote
Old 01-02-2012, 11:55 AM   #2
Rewards Points: 12,794
If you contact the company they most likly will send you one for free.
Could be the cartarage, or pitting in the valve body from lask of use.
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 03:42 PM
Delta 1400 Faucet cartridge replacement johnnie101 Plumbing 1 06-09-2011 08:01 AM
Kohler cartridge replacement Bounce Plumbing 0 04-13-2011 06:21 PM
Jacuzzi Faucet Cartridge replacement help groverwilliams Plumbing 0 09-11-2010 11:59 AM
