Carrying Water Heater On Its Side? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2010, 02:57 PM   #1
Seasoned DIYer
Rewards Points: 150
Carrying water heater on its side?
Some guy at Lowe's say it will cause the glass lining to collapse.
Specifically, it's an electric water heater.
I know that anode rod suspends vertically. Would the lateral stress cause it to snap bend or snap if I carry it on its side? If so, is it just a matter of removing the anode rod and carrying it separately so its not stressed at the mount?
Guy at Home Depot says its perfectly ok
HVAC_NW is offline   Reply With Quote
Old 10-03-2010, 03:05 PM   #2
Chicago, IL
Michael Thomas's Avatar
One problem is that the turbulator may become detached and slide down onto the burners, where is gradually collapses as it overheats:
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-03-2010, 03:25 PM   #3
Seasoned DIYer
Rewards Points: 150
Any problem carrying a electric one in my car?
Old 10-04-2010, 05:45 AM   #4
Rewards Points: 1,216
I just bought one home from the depot (electric) and installed it for a friend it was laying down ... works like a charm.. maybe I lucked out.
Just go easy and try not to bump it to much or bang it around. Good luck.
COLDIRON is offline   Reply With Quote
Replaced water heater, still smelling sulfur in hot water & Low water pressure aminus21 Plumbing 2 07-21-2010 04:40 PM
settings for indirect water heater doug32 Plumbing 0 07-14-2010 06:04 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
