Caps On Pipes For Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2010, 04:03 PM   #1
Caps on pipes for washer
Hello. We just moved into an older house and got our washer and dryer delivered, however are not sure how to remove the caps off the pipes. They are round with no apparent way of removing them with a wrench or pliers.. any suggestions?
mayorp is offline   Reply With Quote
Old 04-06-2010, 04:47 PM   #2
Rewards Points: 352
can you post a pic.
plumberinlaw is offline   Reply With Quote
Old 04-06-2010, 04:49 PM   #3
http://picasaweb.google.com/natplast...44742900052018
Old 04-06-2010, 05:28 PM   #4
Rewards Points: 1,766
Not sure but have you tried some channel locks or similar to see if they unscrew?
bob22 is offline   Reply With Quote
Old 04-06-2010, 06:20 PM   #5
fabrk8r
fabrk8r's Avatar
Those are called "Sharkbite" stops. You can go to your local DIY store and get the tools you need to remove them. http://www.sharkbiteplumbing.com/tools
fabrk8r is offline   Reply With Quote
Old 04-06-2010, 07:21 PM   #6
Rewards Points: 292
Yes little red plastic C clips that slip over the pipe you push up hard and off they slide. Make sure the water is shut off first.
Jim F is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
