Capping Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2013, 04:23 AM   #1
Capping water pipe
Hi,
I'm removing an electric shower and need to remove the water feed pipe.
The pipe runs through the roof space, so I was thinking of cutting the pipe back and capping it somehow.
Can someone give me some advice as to the best method.
Is a compression fitting adequate, or is this type of fitting not preferred if the fitting is in a hidden location such as the loft?
Tha me for an URL you can offer
fivetimes is offline   Reply With Quote
Old 03-29-2013, 06:32 AM   #2
DIY staff
Rewards Points: 7,174
You did not tell us what the pipe is made of----different caps for different pipe-------so let us know--
Old 03-29-2013, 06:48 AM   #3
It's a 15mm copper pipe
Old 03-29-2013, 10:21 AM   #4
Rewards Points: 744
Solder a cap on, or use a Gatorbite/sharkbite-type cap fitting.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
oh'mike (04-01-2013)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
