Capping Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2013, 01:15 PM   #1
I am interested in removing a toilet to reuse the space for storage. However, I still want the option of reinstalling a toilet at a later date.
The floor is bare concrete. Is it possible to remove the current flange and install a flange with a knockout plug? I want the floor/plug as level as possible and safe from fumes. How long can this set up last? Would like to avoid using a test plug because the test plug sticks out too much.
Judy
jpcavin is offline   Reply With Quote
Old 10-07-2013, 08:07 PM   #2
Master Plumber
Benplumbing's Avatar
A lot depends on the type of material they used for the closet collar / piping underfloor. Call a plumber though that would be your best bet. Will probably have to break a little concrete around the collar if you want this flush as possible to the existing floor.
Benplumbing is offline   Reply With Quote
The Following User Says Thank You to Benplumbing For This Useful Post:
plummen (10-08-2013)
Old 10-07-2013, 08:32 PM   #3
Assuming I don't care too much about it sticking out. Does replacing the current flange with a knock out flange provide an adequate seal or would it be best to just put in a test plug and call it a day.
Old 10-07-2013, 08:42 PM   #4
Rewards Points: 218
IMO, a good test plug of the proper size with rubber seal so no sewer gas can leak out would work. Have a plumber check your local codes in your area first.
jmon is offline   Reply With Quote
Old 10-07-2013, 08:50 PM   #5
Thanks guys...a test plug it is. It seems like the easiest option.
The Following User Says Thank You to jpcavin For This Useful Post:
jmon (10-07-2013)
Broken ABS Toilet Flange mnemy Plumbing 7 08-25-2013 12:34 AM
Toilet flange question clambake6 Plumbing 18 03-07-2013 10:25 PM
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
