Hey Folks,
I just purchased a bi-level home and demo-ed the lower level bathroom that adjacent to furnace and water pressure tank. The water is heated through the furnace. We cut and capped -(flux soder welded) the copper pipes to the sink toilet and the baseboard heater there. The welds are holding with no groaning ,creaking or leaks. All the other sinks and showers and toilets work.
Here's the rub-
My father is worried that when we capped the copper pipes that this could cause damage to our pipes and system causing a pipe explosion somewhere. He thinks we should install temp other piping to redirect the water to relieve pressure like a u shaped elbow and have these all repaired by the time we start using hot water and move-in. We will be replacing these fixtures eventually but if it's capped we should be ok? There's no difference between a capped pipe and a closed faucet- is just back flows, right? How does this affect the baseboard plumbing? We are not using the hot water yet because we don't have oil.
Thoughts?
Here's the rub-
Thoughts?
