Old 04-06-2012, 07:23 AM   #1
Capped old Washer drain, pipe leaking (please help)
I have a capped pipe that used to service a washing machine that is leaking from the top. It hasn't been used in about 6 years. I guess I've got a backup problem. Any ideas how to adress this. I'm assuming the problem must be in the main line or even the septic tank? As I said this drain hasn't been used in years. I don't have plumbing experiance but I'm fairly handy. It this something I can tackle myself or do I need to call a pro? If so do I call a plumber or a septic guy? Thanks in advance for any ideas. I need all the help I can get.
Pierson72 is offline   Reply With Quote
Old 04-06-2012, 08:03 AM   #2
Super Moderator
If you must call in help a local plumber would be the place to start---the septic companies may not be able to rod out a drain or perform other interior work---Depends on the company,but around here the septic guys stay outside of the house--
rjniles (04-06-2012)
Old 04-06-2012, 06:51 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Unless ya like swimmin' in Poo,.... Call a Pro.... Roto-rooter type...
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
bathtub drain pipe leaking! starwave Plumbing 8 02-21-2011 10:53 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 01:29 PM
