Cap Off In-floor Basement Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2009, 02:38 PM   #1
bwa
Cap off in-floor basement rough-in
I am in the process of finishing my basement. The builder installed rough-ins in the basement (toilet and sink drain) which stick out about 12" from the concrete floor. They are currently capped off, but I won't be using them, so I need to cut them even with the concrete floor in order to install a subfloor over top. What's the best way to cap the rough-ins after I cut the pipes to ensure they will stay sealed (as they will no longer be accessible beneath the new floor)?
Thanks.
bwa is offline   Reply With Quote
Old 09-15-2009, 09:09 PM   #2
Remodeler
MinConst's Avatar
I am not aware of a male glue in plug for this. I would say your going to have to cap it with a female and make allowances in the sub floor for the cap. If you laying 2x4s for a sub this wont be a problem. If your just laying sheet goods you will need some space to allow room for the cap. Maybe 2x2s in this area. I wouldn't kill the ruffins you may want them some day. Only other way is to chip some concrete away so you can cap the lines flush. Not a bad deal.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-15-2009, 09:19 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
I agree with Minconst about sealing off the rough in's completely you may some time down the road may want to use them.
All you need to do is cut off the pipes flush with the concrete and install and expansion plug. Easy to install and easy to remove later.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 04:39 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 11:27 AM
Replicating rough sawn wood bluefitness Painting 1 01-28-2009 09:54 PM
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 12:24 PM
