Cap On Main Vent On The Roof - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2010, 07:19 AM   #1
Cap on main vent on the roof
Hello, Can a cap say like a flue cap be placed on the main vent on the roof, reason being trying to keep out a rodent from entering the plumbing system have had this happen twice now and becomes a problem ,or should I just put some wire mesh (hardware cloth ) over the roof vent Thanks........ Kerry
kerry42 is offline   Reply With Quote
Old 04-07-2010, 10:15 AM   #2
jlhaslip's Avatar
Rewards Points: 2,864
hardware cloth should do it.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-07-2010, 10:15 AM   #3
If you really need to prevent critters from entering, use wire mesh. If you live in an area where the temperatures get below freezing in the winter, make sure the openings are large enough to prevent snow, rain or ice from freezing and blocking them. I have also seen caps with a metal cover and screening around the lower section. These protect from the freezing problem. The screen is about 3 or 4 inches high.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-25-2010, 08:50 AM   #4
Smile
cap on main vent on roof
Take a look at the website www.johnnycap.com for a nice decorative cap that keeps rodents and debri out.
superiormachine is offline   Reply With Quote
Mid Roof Smart Vent and ice dams mbergm57 Roofing/Siding 5 10-14-2011 05:49 PM
Cutting Vent Hole in Roof How To Wanted wildbilly Plumbing 17 06-02-2010 04:35 AM
Replacing Roof with Certainteed.Replace existing Ridge Master ridge vent? JW Johnson Roofing/Siding 4 11-06-2009 08:59 AM
Can I shingle a dormer without re-shingling the main roof? moparman56 Roofing/Siding 7 10-30-2009 08:20 PM
Vent dryer through flat membrane roof Vince Rosati General DIY Discussions 6 11-02-2008 02:11 PM
