Can't Turn Back Yard Water Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2011, 07:53 PM   #1
Can't turn back yard water off
I have a sprinkler in the back yard that is leaking. I've tried replacing the head and was going to try to rebuild the valve. I shut the main water valve at the front of the house and check to ensure the water was off, all the taps in house house go dry. I went to the back yard, still has running water to the sprinkler and all of the taps in the yard still flow freely. I've look all around the house and can't figure out what is going on. It seems as though there is another main water line feeding the backyard but I can't seem to locate it. Any help would be greatly appreciated!!!
AOdonn is offline   Reply With Quote
Old 12-01-2011, 07:55 PM   #2
Rewards Points: 13,228
Crawl space or basement? Just go under there and look where the sill cocks go through the foundation and trase it back.
Detecting Water Leak in Back Yard melmjd Plumbing 2 11-14-2011 12:56 PM
Plumber turned water off, then back on - now just have warm water... sstat Plumbing 4 02-18-2011 02:18 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
