Can't Snake Bathtub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2013, 09:49 AM   #1
hohadcr's Avatar
Rewards Points: 316
can't snake bathtub drain
Hi, This is something I never solved.
I have a bathtub drain that clogs often, usually because of long hair...
I tried to snake it with the long plumbing snake. However, the head of the snake is bigger than the drain slots. I can;t even put the snake in unless I unscrew the drain slots.
How do people snake the bathtub drains?
thanks
hohadcr is offline   Reply With Quote
Old 03-25-2013, 09:55 AM   #2
Lightfoot's Avatar
Rewards Points: 272
you need to take the drain cover off.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 03-25-2013, 10:07 AM   #3
hohadcr's Avatar
Rewards Points: 316
When I put it back on, I would only need putty to seal it?
Old 03-25-2013, 10:15 AM   #4
Rewards Points: 1,216
Bleach dissolves hair and doesn't discriminate as to length. A couple of applications for bad clogs, allowing to sit a few minutes, followed by nearly boiling water is usually successful. If this is a persistent problem consider a strainer of some sort.
SeniorSitizen is offline   Reply With Quote
Old 03-25-2013, 10:25 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 662
Run the snake through the overflow(remove the trim plate and plunger)
Also, on small drains I run a cable with no blades and a slight kink at the end of the cable- helps to turn 90's
Old 03-25-2013, 05:20 PM   #6
hohadcr's Avatar
Rewards Points: 316
Yes, it has been persistance. every 6-9 month. The renters there are two girls with very coarse long hair. I provided several strainers. Everytime I go check, the strainer is missing. They said once "because it is dirty to pick things out of the strainer. "
And believe me I pray to god that they can move out soon!!! leagally, i cannot kick them out. thanks to our provincial law!
Old 03-25-2013, 06:05 PM   #7
Rewards Points: 636
i have a wife and 4 girls and all use same tub/shower and there hair is extra long.
(long as in my girls have never cut their hair and my wife's hair is almost 6 feet long)
and i use a watco push and pull drain and every 3 weeks we remove the push pull assembly by unscrewing and pull hair out with needle nose pliers from cross bars. never had a clogged drain yet and only takes a minute.
http://wcmind.com/watco/PDFMainFrame.html
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-25-2013, 06:17 PM   #8
DIY staff
Rewards Points: 7,174
You are right---do not unscrew the drain cross thingy---that is what keeps the tub from leaking---
Follow E-Plumbers advice----use the over flow---and try one of those long plastic strips with the barbs---that usually clears the tub drain opening----I use a bent coat hanger some times---
Old 03-25-2013, 06:17 PM   #9
hohadcr's Avatar
Rewards Points: 316
thanks for sharing your experience. My renters can't stand cleaning the strainers. They definitely won't do the cleaning every 3 weeks....
Old 03-25-2013, 06:53 PM   #10
This is how I do it also!
Hardway is offline   Reply With Quote
Old 03-25-2013, 06:55 PM   #11
Rewards Points: 636
they will unless they like waiting in dirty water up to the tub skirt
show them how give them needle nose to keep in medicine cabinet and tell them to have a good day. my wife and oldest daughter will do it now when it gets to the top of there toes.
Old 03-25-2013, 07:15 PM   #12
Plumber
Rewards Points: 662
Buy them some of those zip-it sticks that Mike referred to. If they cant use those on a regular basis- try sending them a bill from a drain cleaner
Old 03-25-2013, 07:45 PM   #13
hohadcr's Avatar
Rewards Points: 316
I probably am going to do the last step: send them a bill.... hard to charge when I do it myself tho, i am thinking of paying an expensive plumber.. then i am afraid they are just gonna not pay me back...
Old 03-25-2013, 07:50 PM   #14
Roofmaster
Rewards Points: 2,210
Use the Hot bleach, Boiling water method, then: fill the tub about 4 inches dry the tub and duct tape off the overflow. Now use your black deep force pump on the drain and blow her clear.
6 feet long, man that must be something to see. Whats her name Rapunzel?
Old 03-25-2013, 07:54 PM   #15
6 feet
Wow I've never seen hair that long. I wonder if she would let you post a picture, Thats amazing.
My girls have long hair too. It does get kind of gross to pick out. I pay my young son a loonie to do it. he doesn't mind
creeper is offline   Reply With Quote
Need a cheap fix to slow bathtub drain need help Plumbing 11 04-26-2016 09:11 AM
Bathtub Drain Stopper BrianinBrooking Plumbing 3 11-10-2010 11:13 PM
drill powered 1/4" snake, bathtub drain Yoyizit Plumbing 10 07-20-2010 10:35 PM
Can't fix bathtub drain KimberlyS06 Plumbing 3 05-08-2010 11:43 PM
Bathtub drain - subgrade jdeters79 Plumbing 3 11-21-2008 03:17 PM
