-   -   can't snake bathtub drain (http://www.diychatroom.com/f7/cant-snake-bathtub-drain-175457/)
hohadcr 03-25-2013 10:49 AM
Hi, This is something I never solved.
I have a bathtub drain that clogs often, usually because of long hair...
I tried to snake it with the long plumbing snake. However, the head of the snake is bigger than the drain slots. I can;t even put the snake in unless I unscrew the drain slots.
How do people snake the bathtub drains?
thanks
Lightfoot 03-25-2013 10:55 AM
you need to take the drain cover off.
hohadcr 03-25-2013 11:07 AM
When I put it back on, I would only need putty to seal it?
SeniorSitizen 03-25-2013 11:15 AM
Bleach dissolves hair and doesn't discriminate as to length.:laughing: A couple of applications for bad clogs, allowing to sit a few minutes, followed by nearly boiling water is usually successful. If this is a persistent problem consider a strainer of some sort.
TheEplumber 03-25-2013 11:25 AM
199 Attachment(s)
Run the snake through the overflow(remove the trim plate and plunger)
Also, on small drains I run a cable with no blades and a slight kink at the end of the cable- helps to turn 90's
hohadcr 03-25-2013 06:20 PM
Yes, it has been persistance. every 6-9 month. The renters there are two girls with very coarse long hair. I provided several strainers. Everytime I go check, the strainer is missing. They said once "because it is dirty to pick things out of the strainer. "
And believe me I pray to god that they can move out soon!!! leagally, i cannot kick them out. thanks to our provincial law!
jaydevries 03-25-2013 07:05 PM
i have a wife and 4 girls and all use same tub/shower and there hair is extra long.
(long as in my girls have never cut their hair and my wife's hair is almost 6 feet long)
and i use a watco push and pull drain and every 3 weeks we remove the push pull assembly by unscrewing and pull hair out with needle nose pliers from cross bars. never had a clogged drain yet and only takes a minute.
:thumbup:
http://wcmind.com/watco/PDFMainFrame.html
oh'mike 03-25-2013 07:17 PM
You are right---do not unscrew the drain cross thingy---that is what keeps the tub from leaking---
Follow E-Plumbers advice----use the over flow---and try one of those long plastic strips with the barbs---that usually clears the tub drain opening----I use a bent coat hanger some times---
hohadcr 03-25-2013 07:17 PM
:thumbup:
thanks for sharing your experience. My renters can't stand cleaning the strainers. They definitely won't do the cleaning every 3 weeks....
Hardway 03-25-2013 07:53 PM
Run the snake through the overflow(remove the trim plate and plunger):thumbsup:
This is how I do it also!
jaydevries 03-25-2013 07:55 PM
they will unless they like waiting in dirty water up to the tub skirt :thumbup:
show them how give them needle nose to keep in medicine cabinet and tell them to have a good day. my wife and oldest daughter will do it now when it gets to the top of there toes. :laughing:
TheEplumber 03-25-2013 08:15 PM
199 Attachment(s)
Buy them some of those zip-it sticks that Mike referred to. If they cant use those on a regular basis- try sending them a bill from a drain cleaner :yes:
hohadcr 03-25-2013 08:45 PM
I probably am going to do the last step: send them a bill.... hard to charge when I do it myself tho, i am thinking of paying an expensive plumber.. then i am afraid they are just gonna not pay me back...
jagans 03-25-2013 08:50 PM
Use the Hot bleach, Boiling water method, then: fill the tub about 4 inches dry the tub and duct tape off the overflow. Now use your black deep force pump on the drain and blow her clear.
6 feet long, man that must be something to see. Whats her name Rapunzel?
:wink:
creeper 03-25-2013 08:54 PM
:thumbup:
6 feet:eek:
Wow I've never seen hair that long. I wonder if she would let you post a picture, Thats amazing.
My girls have long hair too. It does get kind of gross to pick out. I pay my young son a loonie to do it. he doesn't mind
