Can't Remove Washing Machine Shutoff Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2013, 09:02 AM   #16
raylo32's Avatar
Rewards Points: 1,238
I keep a couple pieces of pipe around to use as cheaters. Sometimes that does the trick. Also, have you tried heating the thing up with a torch?
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-19-2013, 09:11 PM   #17
Rewards Points: 338
why hasn't anyone mentioned heat? if all else fails, hit that female adapter with a torch (put some heavy duty foil shiny side up around the plastic to help reflect the heat). it should break it free or at least expand it a bit, then quickly get the wrenches on it before it cools and give it another go.
NitroNate is offline   Reply With Quote
Washing Machine into utility sink help JASON MARTIN Plumbing 10 01-07-2013 09:01 AM
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 11:51 PM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 05:17 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
