Can't Remove Washing Machine Shutoff Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2013, 10:05 AM   #1
Rewards Points: 29
Can't remove washing machine shutoff valve
I need to replace the shutoff valve for my washing machine but am having trouble removing the hold one. Using channel lock
pliers and an adjustable crescent I am putting the backup wrench on the male threaded nut at the bottom and trying to loosen the female threaded valve but it won't budge (dont worry - the picture was taken before removing the washer hose). Not having a lot of room to work with inside that recessed box doesn't help.
Any ideas for loosening up the valve so I can get my nice new quarter-turn ball valves on there?
sparky472 is offline   Reply With Quote
Old 08-17-2013, 10:17 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Use 2 wrenches, the bigger the better.
Are you turning the valve the right way? CCW looking from the top.
Coastal South Carolina
Old 08-17-2013, 10:20 AM   #3
Rewards Points: 29
I'm using two wrenches - a backup wrench on the male nut and another wrench to try and turn the valve - yes, CCW.
Old 08-17-2013, 10:26 AM   #4
A "Handy Husband"
rjniles's Avatar
The reason I said 2 wrenches is your first post said a wrench and pliers.
Old 08-17-2013, 10:53 AM   #5
MarginallyQualified
Rewards Points: 2,464
It's not corroded and you can even see fresh tape.
Wrenches really should do it.
Odds are you're fighting a cross thread.
Go at it with the expectation of replacing everything afterward.
Old 08-17-2013, 05:42 PM   #6
CitadelBlue's Avatar
Rewards Points: 97
I'm the kind of person who like it when my bride cuts OFF the water when she is finished with the laundry ...... the valves you have and are replacing don't last and usually leak either in the stem or weep in the valve itself. ....... you might just want to bite the bullet, open the wall and do some soldering or use the sharkbite fittings and replace the valves with one of these:
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is online now   Reply With Quote
Old 08-17-2013, 06:06 PM   #7
Rewards Points: 29
@rjniles - yeah, I missed that thx. Tried two wrenches, won't budge.
@tarheel - Tape can't be too fresh. I've been in the house for almost 5 years.
@citadel - I agree with shutting it off and I want one of those single throw shutoffs, but the spread is too small for my pipe config.
Here's the thing. Looking closely at the other valve, the tape doesn't look like its wrapped around the threads where I think the male threaded pipe connects to the female threaded valve. Maybe I've got it wrong and the male threads are part of the valve and the nut at the bottom is female? I guess either way, it would t change anything as far as how I'm tying to separate the two...
Old 08-17-2013, 06:16 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Theres a nut on bottem side of washer box,then thers a either a female adaptor on the water line screwed to it,or the line is sweated onto the valve .
thats my guess anyway.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
jmon (08-17-2013), oh'mike (08-17-2013)
Old 08-17-2013, 07:37 PM   #9
Rewards Points: 2,634
When you want to put a lot of torque on a fitting, you need a LONG wrench. Hammering on the wrench, pliers, etc, are all a waste of effort. If you don't have a couple of long wrenches, either buy them, or try slipping a piece of pipe on the wrench you do have.
SPS-1 is offline   Reply With Quote
Old 08-17-2013, 08:31 PM   #10
Rewards Points: 218
Sparky, I agree, that close up looks like a male threaded shut off valve screwing into a female threaded connector. By the looks of it, you would think it would come right off. Try some PB blaster, tap it few times let it soak for awhile and try again. Remember to use counter acting force with two wrenches so you don't break the pipe. If it still doesn't budge your problem may be underneath as plummen suggests.
jmon is online now   Reply With Quote
Old 08-18-2013, 07:22 AM   #11
raylo32's Avatar
Rewards Points: 1,238
Hey, Ken... a little OT re: the OP's question but I agree. I took it a step farther with one of these. It automatically shuts the valve in up to 2 1/2 hours depending on how far you throw the lever. I put it in yesterday in place of simple boiler drain valves so I had to do a bit of re-work to the copper pipes to add the adapters. But if you have the valve in your picture you can pop one of these on in about 10 minutes... just remove and replace 2 screws, and a good idea to use the new o-rings that come with it.
Alls you would need is this valve head:
http://www.amazon.com/Keeney-Manufac...=timeout+valve
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 08-18-2013, 07:48 AM   #12
An old Tradesmen
Rewards Points: 6,516
Attachment 74995
The valve is the male, not the adapter its screwed into.
As said earlier. Big wrenches give better torque.
Old 08-18-2013, 08:27 AM   #13
raylo32's Avatar
Another trick if the alignment works out is to brace one of the wrench's handles up against the wall or stud where it will stay once you put torque on the other wrench. Then you can put all your strength into turning the one wrench. Looking at your picture it really looks like it should come off... unless maybe it got cross threaded and galled up on install.
Old 08-18-2013, 08:38 AM   #14
PoleCat's Avatar
Rewards Points: 1,646
Two pipe wrench face to face 30 degrees apart. Squeeze the handles together.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-18-2013, 08:54 AM   #15
Rewards Points: 29
@jmon - tried pb blaster. No luck.
The problem with longer wrenches is they tend to be thicker too, and there simply isn't enough room to fit them in. Today I'll see if I can go buy a length of pipe that will fit over my wrench handles and try that. Hope it works. Otherwise I'm going into wall, cutting off pipes, sweating new connections. Not what I feel like doing today!
Washing Machine into utility sink help JASON MARTIN Plumbing 10 01-07-2013 09:01 AM
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 11:51 PM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 05:17 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
