Can't Remove An Old Bathtub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2011, 08:49 AM   #1
Can't remove an old bathtub drain
I'm trying to replace the drain in my bathtub (Just the part that screws in to the drainage pipe, not the pipe itself). The old drain won't unscrew though. I applied WD-40 and let it soak. Then I used the handles of some channel locks to stick into the drain and twist it out, but it was so rusty that with barely any force the piece I was pushing against broke. Has anyone run into this problem before and come up with a solution?
paulcody23 is offline   Reply With Quote
Old 08-05-2011, 08:58 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Heat the old putty under the drain lip with a hair dryer on high heat to soften it up.
Cut a small V notch in the rim of the old drain lip with a hacksaw blade and tap it around counter-clockwise with a flat blade screwdriver and hammer to unscrew it.
Good Luck!
Mike Swearingen is offline   Reply With Quote
The Following User Says Thank You to Mike Swearingen For This Useful Post:
paulcody23 (08-05-2011)
Canít remove tub drain, any ideas? becikeja Plumbing 10 07-18-2011 05:43 PM
How to handle bathtub drain when leveling floor Homerepairguy Plumbing 9 12-11-2010 04:47 AM
Can't fix bathtub drain KimberlyS06 Plumbing 3 05-08-2010 11:43 PM
Removed plunger type drain assembly but bathtub still wont drain. Please help lydiarosestiles Plumbing 3 05-01-2010 11:59 AM
Tile Grout in Bathtub drain naitek Plumbing 1 09-01-2006 07:33 AM
