Can't Remove Frozen Toilet Flush Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2013, 12:17 AM   #1
Rewards Points: 27
Can't remove frozen toilet flush handle
Okay, I thought replacing the flush handle would be a 5 minute job, but when I pulled off the tank lid I found that the nut and bolt threads on the inside of the tank were encrusted with what I'm assuming is limescale (see pic). I wasn't able to loosen it at all. I'm going to try some limescale remover tomorrow, but from what I've read about it, I don't have much hope, seeing as how there's really no way for me to soak the bolt/nut. I can't hacksaw through it (no space/leverage), so if the limescale remover doesn't work, I'm thinking the only options I have left are: 1) reciprocating saw, 2) nut splitter, 3) new toilet tank. Am I missing something obvious?
Btw, we just bought this house, so I have no idea why the flush handle is covered in limescale. Doesn't make sense since it shouldn't have regular contact with water.
kevind is offline   Reply With Quote
Old 05-06-2013, 12:54 AM   #2
Lightfoot's Avatar
Rewards Points: 272
try soaking it down in a lubricant such as wd-40 or knocker-loose. then let it sit overnight, or soak it a couple times. Get a wrench or some channelock pliers and it should come off. I've never NOT been able to get one off, and that one really doesn't look as bad as some i've seen.
BTW, you are aware they are left-hand threaded? (not righty tighty like usual) Just sayin.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
The Following 6 Users Say Thank You to Lightfoot For This Useful Post:
Alan (05-06-2013), ben's plumbing (05-06-2013), jaydevries (05-07-2013), kevind (05-06-2013), TheEplumber (05-06-2013), VIPlumber (05-06-2013)
Old 05-06-2013, 02:45 AM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Yep, like Lightfoot said, that will be a reverse thread. Lefty tighty, righty loosey.
JDC is offline   Reply With Quote
Old 05-06-2013, 04:52 AM   #4
Too Short? Cut it Again!
Liquid Wrench would be another solvent possibility.
Old 05-06-2013, 09:22 PM   #5
Rewards Points: 27
Yep, that combination did it. I was using an adjustable wrench before, and it kept slipping. But after I soaked it with wd-40, the channel locks worked fine. Thanks!
The Following User Says Thank You to kevind For This Useful Post:
lazy toilet handle Startingover Plumbing 5 05-27-2012 06:10 PM
Toilet won't flush down contents. kennykenny Plumbing 6 08-23-2011 07:33 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 10:51 AM
